Thread: I am in process of doing my pool also
    iam in process of doing my pool also I have my fc up to 12 now will check in morning, Question is I purchased the walmart great value bleach, it has a green tint to it if you put it in a white cup. were clorox has a clear look. My pool was starting to get clear until i add this patch of bleach, will this go away and clear up or do I need to get some clear bleach. I have sand to change filter sand but dont think Iam quite there yet .
    24 Ft Sharkline Matrix , ~15,200 Gallons
    Pentair SD60 w/ 2 speed 1.5 HP Dynamo pump
    Taylor K-2006 --- BBB
    Jun 2011
    NW, OK
    18
    Re: Baquacil to Chlorine Conversion 6-11-11
    Great Value bleach is the only brand of bleach I used in my conversion because it was cheaper. It will clear up.
    18,500 GAL. VINYL IG | HAYWARD TRISTAR 1.0 HP PUMP | HAYWARD PRO SERIES 20 GPM 300lb. SAND FILTER | RHEEM 400,000 BTU POOL HEATER | POLARIS 280 W/BOOSTER PUMP | TF100 TEST KIT
    ok thanks, I will keep pouring in bleach. today I didnt have the big gain in pump pressure this morning. Before today it always went up about 5-8 over night. I vac it out and scrubbed walls. Do you all think its time to change filter sand? I stil lost almost all chrotine reading overnight.
    Re: I am in process of doing my pool also
    You should not replace the filter sand until the overnight FC loss is 1.0 or lower.
    ok thanks, I have noticed that now when I add bleach it doesn't seem to turn green color like first few times. The pool was actually clear today after sun came up.
    That is great! You are definitely making some progress.
