Thread: Repair or replace?
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    353
    Repair or replace?
    I just temporarily repaired a hernia in the sidewall of our 20+ year old pool. There is other evidence of rust as well, mostly at the bottom. It's a 16X32 with a deck all the way around it. My first thought was to replace the pool this winter. But 16X32 seems to be an obsolete size. So replacing the pool requires a major rebuild of the deck.
    My next thought is to reinforce the walls with galvanized sheet metal 2' wide, partially draining the pool and slipping the metal between the posts and the wall. Since the idea is to prevent hernias, there shouldn't be any force that would push the new metal from out of the posts.
    If that isn't advisable...any recommendations on a brand for a new pool?
    Suggestions?
    Thanks.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    22,544
    Re: Repair or replace?
    I don't know if your idea will work but it might be worth a try.
    I'd drain the pool and put the metal between the wall and the liner.
    Sep 2009
    Greentown, IN
    914
    What kind of shape is your frame in? If it's in bad shape too you might risk problems by partially draining it I would think by changing the pressure on the side walls during the procedure if it's in really bad shape.
    Wouldn't you just be applying a bandaid to a problem that will need further attention later? Might depend on how long you are thinking of keeping a pool too. Maybe you could get pieces and parts less expensively than buying a new pool. Might be worth finding out.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Feb 2009
    353
    The rest of the frame seems okay. Yes, it's a band-aid. But being virtually unemployed for two years means that a band-aid will at least let me enjoy the pool a while longer. I anticipate replacement down the road.
    From a structural standpoint I don't see much difference between putting the metal on the liner side versus the outside if its supported. It's a real pain to disassemble being in the deck. Of course it's a real pain to work under the deck as well. My next pool will likely be vinyl.
    Does anyone make a fiberglass free standing pool?
    I haven't seen a freestanding fiberglass pool. (yet)
    But I've seen a floating fiberglass pool!
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    Feb 2009
    353
    The only freestanding fiberglass I've found are round. Not a fit. So it looks like the band aid approach for a while. Since the deck is over it, it won't be visible.
