Results 1 to 18 of 18
Thread: time switch dial stopped
    hi everybody, i'm using a Intermatic T101R201 mechanical time switch & noticed that the pump was not shutting down at night (as usual) & discovered that the clock dial is not turning... so I have been shutting it down and starting it with manual 'on-off' switch.
    anybody know how to make that dial start turning again.
    27ft Above Ground Pool
    Sand filter
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    Re: time switch dial stopped
    If the timer dial isn't moving then the motor may have died. Check this link to be sure the wiring is ok http://waterheatertimer.org/How-to-wire ... timer.html
    You can also get a new motor from them if that is indeed the case.
    Good luck!
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    thanks V_P. i'll look into it this week & report back.
    Sand filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Check it for dirt dobbers or fire ants!
    Oct 2010
    Georgia
    317
    I had the same issue a few years ago and was able to replace just the time clock motor.
    Complete timer mechanism was $60 which I could have replaced in about 15-20 minutes. The time clock motor only from Grainger was less than $20 which took an additional 15-20 minutes to install inside the timer mechanism.
    Be sure to order the correct voltage clock for your timer.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    I just want to thank you all for your replies & your help. You're all very kind and one thing I know for sure: I would have NEVER figured this out on my own...
    Anyway, we opened the box and it was clean; no bugs or dirt. We removed the mechanism , unscrewed & tested the motor...dead! Ordered a replacement (emailed intermatic & they said replacement motor for WG430-3 would be WG430-10D) .
    Will report back with results after new motor is installed .
    Sand filter
    ..ooops..forgot to report back...sorry.
    put new motor in on 6/30 and works perfectly; thanks again!
    Sand filter
    pool shark's Avatar
    Apr 2011
    South Florida
    12
    I encountered the same issue with my clock not working, but I can manually turn my pump on and off. I had replaced the clock timer with the correct replacement, WG1573. With the new clock timer installed, it still does not work. I measured voltage across the clock motor - 240v as specified. I was wondering how you tested your motor?
    I also just had clock motor connected with power and not connected to timer wheel to see if the timer wheel was frozen, but it still did not turn. Any suggestions?
    Thanks
    23,000 gallon inground free form pool with spillover spa, Paramount in floor auto pool cleaner, Hayward C17502 filter, Andrews Advantage Series heater, 2hp Pentair WhisperFlo 26 pump for in floor auto pool cleaner, 2hp WhisperFlo 28 pump for pool filter
    22,549
    Those clock motors turn very slow. You probably can't see it turn. The best thing to do is install it and hook it up and come back an hour or two later and see if the dial has moved.
    May 2009
    Youngsville NC
    395
    You should be able to see some gears moving behind the front plate (there should be a hole so you can do this).
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    pool shark's Avatar
    Apr 2011
    South Florida
    12
    I looked through the little "viewing window" on the timer to see if it was moving, it didn't look like it. I thought the same thing, maybe it was moving really slow, so I hooked it up and left it. I came back in a couple of hours and the clock had not moved from the time I left it. It is very strange. It is possible that the motor is bad new out of the box, but I ordered two motors(one is for my sprinkler timer that also died). They have the same ratings 208-277v, just different size gears. I hooked that motor up and that one didn't work either - two bad motors???? I ordered them from grainger. I am going to have to dig deeper and see if I can figure out what is going on here. It seems to be all correctly wired.
    For now, it is manually on and off
    22,549
    Have you checked the voltage to make sure you're getting 240 volts to the timer motor? I'd guess that's your problem. It would be astronomically improbable that you'd get two bad clock motors.
    May 2009
    Youngsville NC
    395
    Seconded - the wires for the timer motor need to be on terminals 1 and 3 (the line side). Terminals 2 and 4 are for the Load (in our case - the pump motor). Terminal A would be used for Neutral (for both line and load) if necessary.
    pool shark's Avatar
    Apr 2011
    South Florida
    12
    Thanks for the input from everyone. I actually didn't remove the white wires from the 1 and 3 terminals, I pulled the spade plugs from the timer motor and put them into the new motor. I checked voltage at the terminals 1 and 3 - 240v. I will have to go back and recheck everything again to make sure, but I am pretty sure I was getting 240v. I guess I wouldn't have 240v at the clock motor unless I was getting 240v at the 1 & 3 terminals. I will let you know when I double check them.
    Thanks again.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    If you actually have 240v on the motor terminals and the motor is not running, then the motor is bound (either internally or by the gear train) or bad electrically. If the mechanical train is separated from the motor and the motor still doesn't run w/ voltage applied to it, then the motor is bad. If it runs while removed from the gear train, then the mechanical movement is the problem. Also, open windings can be tested w/ ohm meter (power OFF).
    pool shark's Avatar
    Apr 2011
    South Florida
    12
    I contacted Grainger where I bought the clock motors,ordered another clock motor. I received a replacement motor on Friday. I replaced the clock motor with the "new"/newest one and it works!
    Turns out I received two bad clock motors from Grainger, strange. They replaced it no problem, I'm glad it works, because it was driving me crazy. I can't tell you how many times I measured the voltage on that thing....
    Thanks for everyone's input.
    22,549
    That is so strange. The chances af getting two bad motors in a row is almost non-existent. Glad you got it sorted out.
    Jul 2008
    Flintstone, GA USA
    112
    Quote Originally Posted by pool shark
    Exactly why I order parts from the same company that manufactured the timer even though Grainer was cheaper but look at all the time you wasted.
    Tom
    18 x 36 Grecian Polynesian Fiberglass Walls with Concrete bottom - 3 ft to 9 1/2 ft. deep -
    Hayward Variable Speed Super Pump SP2600VS 1 1/2 True HP,Hayward sand filter S200, and Hayward auto clorinator. Hayward 250,000 natural gas heater. PoolKeeper automatic water leveler. Loop Loc Ultra Solid Safety Cover. Hayward Color Logic 12 volt light. Dual Pool Deck Jets.
    Polaris 380 auto cleaner. Trouble Free Test Kit TF-100.
