Results 1 to 10 of 10
Thread: pool liner question
    pool liner question
    when installing a pool liner over 1 1/2 inch foam what do you do with the liner...If the liner is a bead or semi bead and goes into the wll track for attatchment how do you handle this? Im kinda confused, everyone says to lay the foam inside of the pool walls and cut to fit, but this raises the liner up the thickness of the foam and it would seem that the liner would get a lot of wrinkels...Newbie here so be patient with the stupid questions...Thanks
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: pool liner question
    beaded liners need to have accurate depth measurements. If ordering a custom liner you want to use the shallowest depth found. You are right, you will get wrinkles there is too much material.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    so would it be better to just plan on using a over the wall liner, just trying to figure out all the scenarios before we commit to buying a pool
    30,432
    I have never heard of using 1.5 inch foam. 1/4" is commonly used.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I no longer install overhang liners, we convert them all to beaded liners. They look a lot nicer plus there is the advantage of not having to disassemble the top rail for future liner replacements. I would go with beaded if you can.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Mar 2007
    Coastalish 'down easter'
    4,160
    Quote Originally Posted by X-PertPool
    +1
    Welcome to TFP!!
    Luv& Luk
    -Ted
    Stupid me..got to thinking about this and I rememberd that if using a thick foam base, that would be the substitue for the normal 2" sand base under the liner..DUH
    Apr 2010
    Western North Carolina
    44
    drg,
    You are right on target. I used 1" under my pool on concrete and my beaded liner did just fine. No wrinkles at all. You can figure that 2 inches of sand is going to compact down to 1.5" or less. So your 1.5" foam will work great.
    You will like the feel of the foam on the bottom when you are done!
    24' X 52" AGP - On a concrete slab with 1" Dow blue foam board bottom.
    2Hp 2 speed Waterways pump/Cart. Filter.
    Hard Plumbed 20' away
    Deck 1/3 around pool
    Pool Rover Jr.
    DIY project
    Best Pool Store Quote, "THAT BLEACH WILL DESTROY YOUR LINER."
    Thanks for the support, sometimes thinking can get you in trouble haha
    Mar 2007
    4,160
    Quote Originally Posted by drg
    But not as much trouble as not thinking
    Luv& Luk
    -Ted
