Thread: aquabot t4rc doesn't move but pumps water
    hi all,
    my aquabot will not move but it does pump. How can I test to see if it is power supply, cord or motors? Does anyone have a wiring schematic so I can see how this works?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: aquabot t4rc doesn't move but pumps water
    I don't know a whole lot about these, but it sounds like one of the two motors is shot.
    Oct 2007
    Parkland, FL
    752
    if its under warranty, have it repaired, if its out of warranty, junk it. those motors are expensive.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Toronto Canada
    20
    Quote Originally Posted by robl45
    Exactly, and unfortunately it is most likely a dead motor.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
