Results 1 to 7 of 7
Thread: kblackwell says hi from the Central Valley in California
    Jun 2011
    Stockton, CA
    10
    Just discovered this site. Been struggling with the pool for years - mainly because i didn't appreciate the importance of correct chemistry. just ordered TF100 so there may be hope after all. Thanks to the moderators and others that keep this going.
    Kevin Blackwell
    38X18, 22K gal, in ground, kidney shape, gunite & white plaster, 1 HP Sta-Rite Max-E-Pro, 32 ft2 DE filter, KreepyKrauly auto pool cleaner, TF-100
    space
    Feb 2008
    Denton, TX
    5,061
    Re: kblackwell says hi from the Central Valley in California
    Welcome to TFP!
    30,416
    Good morning, kblackwell!
    Welcome to the forum
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome
    You're done SLAMing when:
    Sep 2009
    Greentown, IN
    914
    Welcome! You will be glad to have found this place. The people here are great & very helpful!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    nutjob's Avatar
    May 2011
    Dallas
    109
    Welcome and enjoy the camaraderie and knowledge.
    I laugh—to disguise the tears.
    Size 15,000 gal 510′² | Filtration DE 48′² | Sanitation SWG+O₃ | Placement in-ground (IG) | Finish pebble
    Pumps Intelliflo VS+SVRS main WhisperFlo WF-28 feature | Location Dallas TX US (33ºN 97ºW)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    If you display the usual reaction to a new test kit, your pool should be clearer than you ever thought imaginable within 2 weeks. It's okay, even normal, to test everything every day. Tip: CYA won't change much unless you add more or remove a lot of water, so save that reagent. Only test CYA once a week. After a month, you'll convince yourself it's not changing, and can go longer.
    Sparklypoolitis can be contagious, but it is essentially harmless.
