First test.
crs16
78
Albuquerque, NM
Just finished filling pool for the first time. Took the test strips we have (insta test 5), I know the TF100 is on its way.
Fc 0
Tc 0.5
TA 80
PH 7.6
TH 50
So according to pool calc, my pool is just under 5k gallons.
So I added 1 quart of bleach to get FC to 3.5
I added a very small amount of muriatic acid (like 1 oz)
And added 1 lb of solid CYA (didn't realize there is liquid available, my lowe's only had dry)
My pump is running, it is a 2650 gph pump so in under 2 hours wi cycle through.
Do I wait 2 hours to test again?
Got my tf100 today. Yay!!!
Results
FC 4.5
CC 0.5
CYA 25
pH 7.5
I thought from the test strip and the Taylors test that the FC level was closer to 3 than 5. Interesting.
The only thing I'm even mildly concerned about was the CYA. I estimated for 30 and got 25. I live in Albuquerque where it is hot and sunny. I'm trying to figure out if I need to add more CYA. Opinions? The kids have been playing in the pool a lot more with friends, so I've been adding 2.5 cups of 6% bleach to keep the FC up the last 2 days. Would it be worth it to add enough CYA to bring it into the 30 to 40 range?
Cindy,
You are off to a very good start with an excellent understanding of your pool water. It is always a pleasure to read a thread where someone has done their homework as well as you have.
Please don't be so nice to Butterfly or she will soon have to order a larger size sunbonnet :shock: :shock: :shock:
duraleigh said:
Cindy,
Oh, Dave! You better watch out for Butterfly.
Fc 0
Tc 0.5
TA 80
PH 7.6
TH 50
Did you buy your pool locally? I am also in ABQ and in the market for a 15'x52" round.
