Thread: Need help to determine a yellow / brownish spot
    Fresno CA
    24
    Hi,
    I have had a yellow / brownish spot near my main drain in my pool. The spot has been there for about two years before I knew about TFP. I did not think much of it in the past since I did overnight loss test and only lost about 0.5 on my FC.
    What is the best way to determine what kind of spot I have? Sorry I did not include pictures but as soon as possible I can post. I have had proper FC levels for the past two years. Could it be mustard algae and what does it look like?
    FC 20.0 (currently shocking pool)
    PH 7.6
    TA 80
    CH 420
    CYA 40
    Any help is appreciated.
    Dave
    20K gal, 15X30, IG, Plaster, Pentair VF-3050 Intelliflo Pump, Pentair Clean&Clear Cartridge Filter, SWG
    Re: Need help to determine a yellow / brownish spot
    Try putting a vitamin C tablet on the spot for 30 seconds to a minute and see what happens. If it is an iron stain, it should vanish, or lighten significantly, where the vitamin C tablet was.
    Fresno CA
    24
    Ok, I will place vitamin C tablet and see what happens. It is in the deep end about 7 ft any recommendations on which kind of tablets or it does not matter?
    Dave
    Butterfly's Avatar
    South Carolina
    10,045
    Cheap Vitimin C. - the cheap tabs don't have a protected coating that takes time to dissolve.
    Since it is that far down, you might want to crush some in a sock and use a pole to hold it on the stain for a minute or so.
    You're done SLAMing when:
    Fresno CA
    24
    Update! Re: Need help to determine a yellow / brownish spot
    Hi everyone,
    Just an update. I placed some vitamin C tablets in a sock and held it on the spot and it faded away. Problem solved! Actually my wife bought the Vitamin C at Dollar Tree for $1.00 and it has 30 tablets.
    Thanks for all of your help!!
    Dave
    Butterfly's Avatar
    South Carolina
    10,045
