Thread: Filter will be out for a few days, Can I run on Recirculate?
    I have my filter out for repair and de-greasing for a few days, yet my water is starting to turn a bit green (Just recently opened). Can add liquid chlorine and just run recirculate to keep algea at bay while my DE filter is out for repair? (I have to try and patch a hole). Will this hurt anything?
    Learning a ton on this forum. Waiting for my Taylor K-2006 to arrive. Just ordered it.
    16,000 gal in-ground
    Pump: Hayward C48K2N143 1HP 230V
    Filter: DE Triton Nautilus FNS-36
    Re: Filter will be out for a few days, Can I run on Recircul
    Yes, you can set the multiport to recirculate and add liquid chlorine to prevent algae.
    Support the site
    Donldson's Avatar
    NW Ohio
    2,892
    I did that at the beginning of the season because mice had destroyed my catridge filter. It will kill and prevent algae and the other nasty stuff, it just won't filter them out until you get that fixed.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mar 2007
    Coastalish 'down easter'
    4,160
    AFAIK that's the entire purpose of the "recirc" function.
    Luv& Luk
    -Ted
