Thread: TA is around 200
    TA is around 200
    TA = 200
    Ph = 7.8
    FC= 0
    Pool calculator isn't working, so I have no idea how much acid to put in for the TA. Can someone help me?
    Keith
    Intex 15' x 48" AGP (5300 gallons)
    Intex 2,100-Gallon Sand Filter Pump
    Central Mo
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: TA is around 200
    its working for me, clear your cache?
    Yep, even tried in IE, doesn't work. The pH works, but not TA.
    Keith
    Central Mo
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by keithk
    TA = 200
    Ph = 7.8
    FC= 0
    If your goal is to lower your TA, you do that by lowering your pH to about 7.2 and aerating your pool to increase pH back up to 7.8.
    Then do it again, and again, until TA is where you want it.
    It can take days to weeks to accomplish this. There are complete instructions in Pool School.
    So, when you ask the Pool Calculator to figure the amount of MA to lower your pH from 7.8 to 7.2 w/TA 200, I get 25 ozs.
    You're done SLAMing when:
