Thread: Is it possible that two pinholes can let out that much water
    I followed the advice of two people on here about draining my pool find where the leaks are coming from. I found one small pinhole on one side
    and two pinholes next to each other on the other side. I was getting small puddles in those two locations. I hope that was it.
    Tony
    Vinyl 18x36 Single Roman End
    ~26,000 Gallons
    Goldline SWG T-15 Cell
    Sand Filtration
    Pool Tool Zinc Anode
    LaMotte Color-Q Pro 11 Test Kit
    22,539
    Re: Is it possible that two pinholes can let out that much w
    A couple of small holes can leak a lot of water. You figure they're leaking 24/7.
    I once made a poor boy drip system for a newly planted 15 gal tree from a trash bag with a single pin hole placed in the pot the tree came out of. Takes an hour or two to drain.I
    Well I will check the leaks tomorrow. Re level my pool, fill it partly and make sure I am all fine.
    this forum is so helpful!
    ~26,000 Gallons
    Sand Filtration
