Results 1 to 7 of 7
Thread: Important note for BBB
    Nov 2009
    Cleona, PA
    236
    Never ignore checking the pool for a week.
    We had a lot going on last week, and left the solar cover on the pool. Every time I walked by I saw it was still blue and said, I'll have to check the chemistry later.
    Friday AM, still blue, Friday evening... green.
    I'm beating the bloom back into submission, still had some Cal-Hypo to speed up the shocking... but boy, it would have been a beautiful day to swim today!
    13,500 Wilkes Vinyl AG (15'x30' rectangular)
    Hayward Power-Flo LX SP1580, 1HP
    Hayward S-160T High Rate Sand Filter
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: Important note for BBB
    Live and learn, eh?
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Butterfly's Avatar
    South Carolina
    10,045
    Ignore your flowers and they die.
    Ignore your pool and it comes alive!
    You're done SLAMing when:
    Sep 2009
    Greentown, IN
    914
    Nicely said Butterfly! I learned that the hard way late last summer too
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    thepiratemorgan's Avatar
    Aug 2010
    Central NY
    185
    Remember, humans ... much like water, follow the path of least resistance. And I can assure you, I am a picture of "least resistance". My point? Get your testing and FC additions down to a science, if you have your system down to a science, you're less likely to fluff it off. Have your test kit in an easy to grab location, or just the reagents you need to test FC. Have your chlorine, test kit, and a clipboard with a "results" sheet in the same location if possible (cool and dry, of course). Basically I can test for FC and add chlorine in less than five minutes. Five minutes is all it takes to keep that pool clear and safe.
    I made a "Testing Results" sheet that I will upload to the "Testing and Balancing Your Water" forum.
    14,600g / 24ft. Round Above Ground with Solar Cover
    18" Hayward Pro Sand Filter
    1 HP Hayward Powerflo Matrix Pump running 10am - 8pm
    Full Sun (when we get sun ... LOL): Approx. 10am to 7pm
    Using the Trouble Free Method, and loving it!! Arrrrrrrr!!!!
    Nov 2009
    Cleona, PA
    236
    By the end of last year, I had a pattern down, every 2-3 days I would add 'so much' bleach and it was crystal. If I ever tested, it was right where I expected. (I had a lot of CYA last year, so I kept it around 6.) This year, after lowering the water and adding new, my CYA is a little lower, so I'll probably stay around 4-5. Just gotta get my rythm going. It was so easy last year, I took it for granted this year. Pools not losing FC overnight, still a little cloudy, but you can see bottom.
    Vacuumed a few times. We'll be good to go pretty soon.
    Nov 2009
    Cleona, PA
    236
    Got it crystal clear, and am keeping it that way. Kids got to enjoy it this weekend. The liner has pulled away more this season, as the vinyl shrinks. Sad, but it may be the last year for the pool. Can't afford to replace it.
