Thread: Side wall blowout
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    357
    Side wall blowout
    Our pool is old, over 20 years. I just noticed a rust through close to the cove, about two fists in size. The liner (one season old) hasn't failed ...yet. Is there any way to reinforce it sufficiently to get through the season? I suspect a new pool is in our future, since this won't be the only spot to go. Suggestions?
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    22,551
    Re: Side wall blowout
    You could take a metal patch and epoxy it in place on the outside. You'll have to use something to hold it against the side wall until the epoxy sets but that shouldn't be too hard.
    Feb 2009
    357
    The metal was too far gone for epoxy. There is a deck around it, so I used a pt deck board between posts and wedged a piece of 2X 6 against the hernia. Should get us through the season at least.
    Usually, when one area has rusted out, several other areas are about to go. That isn't always true, but it often happens that way.
    Feb 2009
    357
    Yeah. That's why I started "repair or replace". Always something...
