Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Adding sand filter to 18' round Summer Escape pool - HELP!
    How do you attach the sand filter (Intex model 20110) to bottom of the in-wall skimmer? Is there an adapter? Is there a plate you can install where the in-wall skimmer attached to hook the sand filter to? Am racking my brain & could use assistance from some of you experienced people, please!
    Re: Adding sand filter to 18' round Summer Escape pool - HEL
    Welcome to TFP!
    Normally the filter sits on the ground and is connected to the skimmer with a hose.
    I have been searching all day for the answer to this. I ordered a piece http://www.amazon.com/gp/product/B004ZH4GJU haven't received it yet, but after reading the reviews, it seems like it won't work on the filter that comes with the 18' pools. I will try to remember to update after receiving the piece.
    Jul 2011
    Central Califorina
    208
    I just hooked up a 1600 gph intex sand filter to my 12' summer escape pool with thru-wall skimmer. I did not use any adapters. Simply take the stock hose off, (save hoseclamps) then place the intake hose from the sand filter to the bottom of the existing pump (exactly where the other hose was). Again the return hose from the sand filter goes on the existing return of the pool. Use the summer escape hose clamps and tighten (VERY TIGHT). Hand tight will not due you need a ratching hex head driver to tighten the bolts. This has worked with no leaks for my pool for 5 days now. I did not want to make any modifications to my pool as I will be going larger next year.
    The flow from the sand filter is going thru the non-op stock pump but if there is any effect it is minimal.
    BTW upon start up of the sand filter I closed the weir to the thru-wall skimmer and added a cup of DE mixed with water to the skimmer. I did this twice for 2 cups of DE before I saw a jump on my PSI gauge.
    You will be happy with this filter. Combined with the saltwater system I got my pool maintanece has been cut by 90% and the pool looks exponetialy better.
    3500 gallon 14x42 Intex Ultra Frame
    1/2 HP Intex 1600 sand filter/pump - Intex SWCG
    Two 4x20 Fafco solar panels.
    Taylor K-2006
    Marquis spirit hot tub - Grill Dome ceramic grill/smoker
    So you just left the filter motor in the skimmer? That would be great if that works.
    Jul 2011
    Central Califorina
    208
    Yep, just hooked it to the filter motor on the skimmer. Like I said I don't know if it is effecting performance but it works and it is not leaking.
    Taylor K-2006
    Apr 2010
    Four Oaks, NC
    18
    We left the motor on too but I did take the impeller out.
    18 ft round (Intex style) Summer Escape pool
    1hp Hayward pump and sand filter (size escapes me)
    Intex SWG
    Planning an upgrade to a 24ft as soon as we wear this one out!
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Same here! Left the pump on the skimmer and just attached the hose from that pump outlet to the new pump inlet. You can take the impeller out of the motor if you like by removing the screws and separating the pump, then just pull out the magnetic impeller and reassemble. Secure it back to the skimmer and you're good to go! the intex sand filter comes with a variety of hoses and adapters that it's easy to hook up
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Thanks everyone! You all are very helpful!
    I'll be doing this exact same thing to my pool here in the next few days. The impeller came apart on me and there doesn't seem to be any replacement parts anymore. The filter didn't work all that well anyway. I do hope that this new sand filter works better.
    Oh yeah I'm new here!
    I would love to change to a different pump, but the canister on our pump is broke. We have tried to find a new canister and only polygroup carries them. We ordered one two weeks ago and they still haven't processed the order even though I've called them 3 times. We received the new filters we ordered but nothing about the canister because it comes from a different warehouse and they have no control over that and can't expedite. So with no canister we can't do anything unless someone has an idea how we can convert to a new pump and cover up the square hole in the side of our pool. Such a pain! We just bought this pool two years ago and the filter system is no longer available!!!!
    I will never deal with this company again. They are worthless.
    I'm disappointed with the Intex sand filter I installed today using the old pump (minus the impeller). It seems like I may not be getting even as much flow as I was with the stock pump and I'm not really able to vacuum with any significant suction using the skimmer plate. I thought it would be good to be able to vacuum to waste, as I was not able to do that using filter cartridges but this is not really any better.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by robntex
    Which intex do you have?
    I do not know how much head loss you have going through the summer escapes pump, but if you have those long corrugated tubes, they also can cause quite a bit of head loss. I know of one person that had an extra length of those corugated tubes in their pump/filter loop and it kept them from vacuuming effectively with the 1600 gph intex sand filter. Once they got rid of the extra length, then they could vacuum fairly effectively.
    Quote Originally Posted by linen
    I have the 2650, I suppose the tube from the old pump to the sand filter pump could have some trimmed but I would lose the hose cuff. I might measure and buy the smallest tubing for the run and try that. I'm open any options, I was really wanting to open my pool this weekend but it I cant vacuum, I don't know what I'll do. Judging from the reviews of the sand pump, people have had good results but it does not seem to be filtering very good for me.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Did you use the in line plunger type valves in your set up? If so try removing them all together. They really limit the suction/flow.
    Quote Originally Posted by Jamison04
    No, I did not use them. I even enlarged the out flow opening in the pool to accept the larger out - to - pool nozzle.
    We have a Summer Escapes 20x48 and our pump has stopped working. Can I just leave the pump hooked up but take out the propeller/motor and hook up a salt water filter/pump to that? If so, how did you get it out easily? Will the water still flow through good? Thanks in advance for your reply.
    Quote Originally Posted by jwoods0414
    That is what I'm doing (using the old pump with the impeller removed). I had an extra pump with the impeller already broke so I'm not sure how to remove it.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    I've got the same set up using the old pump with the impeller removed and have very good suction through the skimmer and pump and a pretty strong jet of water out the return. I also am using the corrugated hoses so I'm not quite sure why you aren't having better results...
  20. Back To Top    #20
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Hi, can you post a picture of your current set up? Also please post a picture with the position of the multiport valve and the pressure gauge on the filter while it is running.
    Love TFP? Become a
    TFP Supporter!
