Results 1 to 7 of 7
Thread: 2 speed matrix verses dynamo
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I have a 3/4 hp one speed now (service factor of 1.0) and I would like to replace it with a 2 speed. The hayward matrix 2 speed model lowest hp rating is 1 hp, where the pentair dynamo has a 3/4 hp 2 speed model. Somewhere I have seen the the Hayward hp is "max rated" so it might be closer to 3/4 hp?
    Any thoughts on which might be best for me?
    22,548
    Re: 2 speed matrix verses dynamo
    Either will probably be fine for you. To figure the real numbers you need to multiply the hp by the sf, also known as the SFHP. If they match closely then it's basically the same motor.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Nearly all AG pumps are up rated so they should be similar in performance. The best thing to do is to compare the head curves.
    Mark
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by mas985
    I looked at the curves, looks like the 1hp version of the hayward matrix is slightly higher than the 1 hp pentair dynamo...but close. However, the 3/4 for the pentair is lower. I do not know what the head curve is on my current pump to compare to. I have ordered the Matrix 1 hp 2 speed, but am now second guessing myself, and am thinking of the Dynamo 0.75 hp 2 speed. Any thoughts?
    You have a small pool, I would go with the smallest possible pump.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I do have the 4 solar panels on the roof, but my 3/4 does pump fine now...
    mas985's Avatar
    Pleasanton, CA
    11,737
    Another option that is less expensive is to replace just the motor with a two speed motor.
    Mark
