Thread: black algae on calciaum
    just above my water line, i have some build up of white scale which i believe is calcium on my pebble tec. on that build up i have black splotches that turn bright green when the chlorine dips a bit. then i typically raise the water line to cover the green then boost the chlorine.
    i was told this was black algae at my neighborhood pool store. it was recommended i let the water line drop then attack the build up with a pumice stone to remove the build up and ultimately the black algae.
    just wanted to get a 2nd opinion on the best way to remove the build up and also the black algae?
    thanks,
    1) 16,000 gallons
    2) cartridge
    3) in ground
    4) Pebbletec (Shasta stone)
    5) If you know, tell us the size pump and the size (flow rate) of your filter. Need to find out.
    30,403
    Re: black algae on calciaum
    It sure sounds like you have algae and calcium scale. Whether it's black algae or not, the conditions that have caused it will return unless you get your chemistry in check.
    I would do that first and then clean up the scale.
    If you post a full set of water test results, we can give you much more specific advice.
    hi jason,
    my water test from yesteray at leslies pool store
    free chlorine 4
    total chlorine 4
    Salt 2600 ( irrelevant because my salt cell is dead, using chlorine tabs)
    cyanuric acid 99
    total alkalinty 80
    pH 7.4
    phosphates 200
    since the test they had me add 9 oz of phosfree.
    1) 16,000 gallons
    2) cartridge
    3) in ground
