Solar schedule in EasyTouch
Jun 25, 2011
1
This year I cannot get the Solar schedule to work correctly. I have an Intellipro 4 speed pump with an EasyTouch wireless. The Solar has been set-up on the Pool mode on the #4 speed. I set the times for the Pool schedule,set the desired temp, it starts, when the pool gets to the set temp, the Solar valve closes, and the pool pump ramps down to the #1 low rpm speed until the end time of that schedule - or during the schedule if the pool temp drops, the solar valve will open back up and the pump will ramp up to the higher #4 rpm.
Now this year after re-enabling the Solar I cannot get the pump to ramp down once the pool gets to the desired temp. The Solar valve will operate ok according to pool temp setting, but the pump keeps running at the higher #4 rpm instead of ramping down to the lower rpm.
