Thread: Filter is leaking bad due to a crack around the neck
    I own a 15' round above ground pool with a sand filtering system. The filter is leaking bad due to a crack around the neck. I am now looking for a new sand filter and 1hp pump. What do you recommend? I would also like to convert to a salt clorinator. What do you recommend?
    Thanks
    Intex 15' x 48" with SWG
    FC 5
    pH 8
    TA 80
    C .1
    Re: Filter is leaking bad due to a crack around the neck
    Welcome to TFP!
    Get the largest filter you can afford and have room for. Larger filters go longer between backwashing and filter better overall. Look for a two speed pump, running a two speed pump on low can save a lot of money on electricity. The Intex SWG is basic but works well. The next step up, the AquaTrol, is noticeably more expensive but includes several nice extra features like a pump timer.
