Results 1 to 8 of 8
Thread: Can you maintain shock level with a swg?
    I came home from work to find a greenish pool with visible algae growing on the sides. When I was away my wife helped out by vacumning the pool. When she turned off the pump to remove the hose she left it off for three days. Anyway, I added 3 5l bottles of chlorine 10% and will vacumn to waste tomorrow. I also added some pucks to a floater and set the generator to 100%. Will I need to add more bottles over the next few days or will the pucks and swg be enough?
    test prior to treatment
    fc 1.0
    tc 1.2
    cc .2
    ph 7.7
    hardness 90
    cyanuric 65
    alkalinity 101
    salt 2900
    18300g kidney
    haward pump cartridge filter and swg
    Re: Can you maintain shock level with a swg?
    Best to rely on outside sources to keep FC up, save your cell. I am shocking now with SWG off, need it off to pass overnight chloine loss test.
    Butterfly's Avatar
    South Carolina
    10,045
    An SWG can't produce enough chlorine fast enough to shock your pool, but the SWG can help you maintain shock level. Liquid chlorine/bleach is recommended for shock. See "How to shock your Pool" instructions in Pool School.
    The amount of chlorine needed to complete the shock process depends on each case. You are done shocking when you meet three criteria. See red line in my sig.
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by anonapersona
    This is good advice. Save the wear on your SWCG cell and shock with pure bleach.
    Jul 2007
    Brisbane, Australia
    874
    you can, but such SWG will be unusable for normal day to day operations due to greatly larger output
    properly sized SWG won't be able to achieve required levels
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Answer is no. Why would you tax your SWG when bleach will work better faster and cheaper.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    you should target cya of 80. a higher cya would have helped keep more chlorine in the pool even over those days when pump was off.
    run your pump 24/7
    yes shock your pool with liquid chlorine until its clear. no point in using pucks. let the swg work. and brush the algae will help the fc kill it.
    I think it is easier to know what is happening if SWG is off. Calculate bleach to add, circulate, retest to confirm level then monitor FC drop over time and add bleach as required.
