Results 1 to 8 of 8
Thread: Polaris 360 cracked frame repair
    Aug 2007
    Denton, TX
    48
    My 360 hasn't worked well since we bought the house/pool (it came with it). I've been cleaning the pool by hand, but there's a live oak over the pool that's dumping TONS of acorns & leaves in it and I'd like the polaris to deal with those.
    So today I took it apart and discovered that the frame is cracked, directly below the drive shaft. This lets the frame flex enough that the gears sometimes don't mesh. Also, 2 of the bearings have lost all of their balls.
    I've found tune up kits for about $100 that will replace all of the bearings, gears, belts, etc.
    But the frame alone is another $100. I'm considering repairing it with epoxy, liquid nails or something similar.
    Has anyone done a similar repair to a polaris, or other plastic cleaner? What adhesives, epoxies, etc. are recommended for swimming pool/chlorine applications?
    13K gal - IG gunite/plaster - 1 1/2 HP pump - 300lb. sand filter - SWCG
    Support TFP!
    CRG_80cc's Avatar
    Jul 2007
    Nor-Cal
    81
    I would use Gorilla Glue. It's passes ANSI/HPVA HP-I-2000 Types 1 and 2 (waterproof)). Just don't use very much. Use a toothpick to put it between the cracks. It expands when it dries for some reason but it is strong. Oh yeah, use clamps to hold the pieces together until the glue is fully cured.
    30K gal. IG Free form
    Cartridge Filter, Solar and Gas Heater
    Using BBB
    Aug 2007
    Denton, TX
    48
    Just following up on this old post to say the Gorilla Glue worked perfectly. Had to make a jig to clamp the odd angles of the frame and made sure not to have any glue squeeze out anywhere that another piece had to sit flush against it. Installed a $99 rebuild kit and my 360 is good as new!
    Support TFP!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hoo- Rah!!
    Now we know that the units can be mended with a touch of Gorilla Glue -- I'm sure others will find this useful
    Luv& Luk
    -Ted
    30,419
    Hey, Jules,
    Nice work!! I don't know what Gorilla glue is. Is it a two-part epoxy?
    CRG_80cc's Avatar
    Jul 2007
    Nor-Cal
    81
    Hey, Jules,
    Not at all. Very easy to use right out of the bottle. You can find it just about anywhere in the hardware section. Just use less than you think. It expands abit when it cures.
    TFPJules111, glad to hear it worked. Better to spends $100 on something else than a new frame
    Using BBB
    Aug 2007
    Denton, TX
    48
    Re: Polaris 360 cracked frame repair
    Just to give an update, a little over a year after the repair and the Polaris is still running great. Hurray for Gorilla Glue!
    Support TFP!
    JoshU's Avatar
    New Orleans, LA
    542
    I've always fixed frames this way, too.
    Just for reference if you do need a new frame you need to send your old frame back to Polaris before they'll send you a new one. They don't just sell the frames to dealers without getting the old one back first.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
