Thread: Quick please! Would these pool steps work with Intex?
    http://chicago.craigslist.org/chc/for/2457789375.html
    seems like a great deal, if they would work with my type of pool....anyone know if this works with an Intex??
    many thanks!
    First time pool owner!
    Intex Ultra Frame 18x9x52 rectangular pool
    4545 gallons
    Intex 2100 GPH Sand Filter/Pump
    Intex SWG
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Quick please! Would these pool steps work with Intex?
    Dont know, I would surely measure before I took em home.
    Essential Links:
    22,553
    They should work fine. The hieght won't give you any problem. Check the bottom of them real well. If it's rough it could puncture the liner. A pad would take care of it if it isn't too bad.
    Thank you both, we're going to check them out. A pad on the bottom is an excellent idea.
    Just ordered the test kit too, now we just need to get the darn pool set up!
    4545 gallons
    Intex SWG
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey, good luck! I hope you get a good discount.
    Essential Links:
    Should do fine. I have a similar set on my blue blob. They probably wouldnt work on most blow ring pools, but mine is a little out of level, so it has a side that stand up pretty straight, and that is where I put the steps.
    They beat the heck out of the cheesy A frame ladder!
