Results 1 to 9 of 9
Thread: MA substitute?
    Jun 2011
    Albuquerque, NM
    77
    MA substitute?
    I was at Lowe's yesterday and couldn't find any MA in the pool area. I did find something else that said it replaced MA, active ingredient is Sodium Bisulfate?
    Is that an acceptable alternative? Pros/cons?
    And where does lowe's store there MA?
    Cindy
    4.8 K gallon AGP: sharkline opera 12'x17'x52"
    Sandpro 4511 sand filter and pump
    Re: MA substitute?
    Sodium bisulfate is what we call dry acid. You can use it to lower PH, but it tends to cost a lot more than muriatic acid.
    Muriatic acid is different places in different Lowes. Sometimes it is in the covered outdoor area. Sometimes near pool supplies. It can also be in the paint area, or by concrete products.
    Jun 2011
    Albuquerque, NM
    77
    Re: MA substitute?
    Thanks Jason!
    Cindy
    Cindy
    Feb 2008
    Denton, TX
    5,061
    Re: MA substitute?
    If you have a Home Depot nearby, you will find it outside in the lawn/garden section where the pool supplies are. Most places have it on a pallet in brown boxes with 2 1 gallon bottles in each box.
    Jun 2011
    Albuquerque, NM
    77
    Re: MA substitute?
    Thanks! Found it in the paint section with solvents and such.
    Cindy
    Feb 2008
    Denton, TX
    5,061
    Re: MA substitute?
    Be sure and check the strength on the bottle. It can vary and makes a difference when it comes to calculating the amount that you need to add.
    Jun 2011
    Albuquerque, NM
    77
    Re: MA substitute?
    It's the 31.45% by weight concentration. It seems I remember that number from somewhere else on this board.
    Cindy
    Feb 2008
    Denton, TX
    5,061
    Re: MA substitute?
    Quote Originally Posted by crs16
    That's what you want. Some places sell it at about half that strength and often, for the same price.
    Jun 2007
    New Jersey
    653
    Re: MA substitute?
    We have two HD's nearby, one in Raritan and one in Bridgewater (NJ), about ten miles apart. The one in Bridgewater cannot carry MA due to municipal regulations on hazardous storage and the other one can and does. Not your case, but there may be places where it simply is not there.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
