Results 1 to 10 of 10
Thread: does cal-hypo always cloud water?
    current readings:
    fc: 7
    cc: 0
    ph: 7.5
    ta: 110
    ch: 230
    cya: 60
    migrating to bbb since i found pool school and this excellent forum. however, i still have a supply of cal-hypo (68%) which i sometimes use to chlorinate instead of bleach since my CH numbers are on the low side. i've noticed that it seems to cloud the water a bit, especially in larger quantities. just wondering if this is *always* expected w/cal-hypo.
    20k gal, cartridge, IG, plaster
    22,549
    Re: does cal-hypo always cloud water?
    With a CH and TA & the pH you have listed there's a possibility that it is going to cloud the water if added in large quantities. It should clear in a little while though. Just add smaller quantities.
    Jul 2010
    England, UK
    156
    My pool starts to cloud when the pH goes over 7.8. My TA, CH and CYA are all pretty much the same as yours.
    The cal hypo looks a little cloudy when it first goes in, but clears very quickly as long as the pH is in range.
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    30,419
    pre-dissolve the cal-hypo in a 5 gallon bucket and pour the slurry slowly into the skimmer. That usually prevents any clouding.
    I added some cal-hypo this week, yep, clouded the water. It did clear up after a day or so.
    Keith
    Intex 15' x 48" AGP (5300 gallons)
    Intex 2,100-Gallon Sand Filter Pump
    Central Mo
    Diver's Avatar
    May 2011
    South of Boston
    450
    Dave,
    Is it ok to pour into a skimmer? i have some cal-hypo that i want to use up and it doesn't seem that it dissolves in the bucket entirely and there are lots of granules left behind. i have a DE filter and i think all of them will end up there. they will probable dissolve there though ...
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    X-PertPool's Avatar
    Exeter, PA
    1,385
    skimmer is fine, the key is to pour slowly as not to overload the skimmer basket. Also if you happen to have any tri-tabs in your skimmer basket remove them prior to pouring.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jul 2010
    England, UK
    156
    i remember one of the other people on the boards saying don't pour cal hypo in your skimmer if you're likely to have stabiliser dissolving on your filter. make sure you've done at least one backwash since adding stabiliser. it sounded like good advice to me.
    Diver's Avatar
    May 2011
    South of Boston
    450
    how about bleach in the skimmer?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Not that I recommend this but I have added cal hypo through the skimmer then dumped 8 pounds of stab into the skimmer. the basket gets filled but the water can still pass through, also some pumps can handle their baskets getting filled with stab while others will stop pumping. Most chemicals can be poured into the skimmer safely with the exception of a few like acid or soda ash (it can turn hard like a brick)
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
