Thread: Can you add a freeze guard to a regular Intermatic timer?
    Aug 2007
    Denton, TX
    48
    Hi All,
    Temps are still nice around here, but I want to be prepared if/when they drop.
    Have a perfectly functional Intermatic 220v timer to run the pump. All of the "freeze guard" stuff I've found on the 'net includes the timer.
    Is there anyway to add just the temp sensor component to a regular timer?
    If so, I'd guess it has to be tied into the timer, since if it went before it pump power would still be dependent on the timer regardless of temp. And if it went after it, freeze guard power would be dependent on the timer.
    Thanks for your input.
    Julian
    13K gal - IG gunite/plaster - 1 1/2 HP pump - 300lb. sand filter - SWCG
    Support TFP!
    You can add a separate freeze protection thermostat, such as the Intermatic PF1102, in parallel with your existing timer (so that either one can power the pump). Or you can replace the mechanism of your existing timer with something like the Intermatic PF1102MT combined timer freeze protection thermostat. Intermatic makes a number of related models with various additional features, so you have several choices beyond the specific models I just listed.
    sammm's Avatar
    North Richland Hills, TX
    257
    My freeze guard is integrated in my timer as well. Intermatic PF1103T.
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    Aug 2007
    Denton, TX
    48
    Thanks for the input.
    Looking at the prices, the freeze controls cost almost as much as integrated freeze/timer, so I suppose it makes more sense to just replace the timer.
    Support TFP!
