Results 1 to 9 of 9
Thread: Intex pump flow issues
    May 2011
    New Iberia, Lousiana
    27
    Hey all,
    I have been having a problem over the last couple of weeks with flow. I currently have a Krystal Clear Filter Pump 637R and Krystal Clear SWG CS8110. It started out that we had to change our first filter after about 10 days as we could not clean it enough to get flow. The next filter worked well for about 5 days and then same thing. I used a generic A filter last night and by this morning I was getting low flow again.
    Each of the filters have come out with a dark coloring in the filter after only a day and again cleaning them only works so well.
    So I know that the pump we are using is really not the best as far as overall flow and efficiency however I had hoped it would last at least one year before we had to replace for a larger pump.
    Over all the poll numbers have been good and the water is clear but for some reason the filter gets funky quick.
    So do I get a bigger pump? or is there something I can do with the filters/pump so they don't clog so quickly?
    INTEX 14 ft Round x 42 in Deep, Krystal Clear Filter Pump 637R, Krystal Clear SWG CS8110
    22,550
    Re: Intex pump flow issues
    I don't think it's a pump problem. Sounds like you have something going on in the pool. Can you provide us with a full set of test results and how you got them?
    May 2011
    27
    I will get some when I get home from work but here is my last set.
    FC 2.5
    CC 0
    TC 2.5
    PH 7.5
    T/A 130
    CH 400
    CYA 70
    At the time I added the recommended Clorox and Acid. I know the FC/CC/TC is a little low from this test and when I test tonight I expect it to be low again. We got a lot of rain this week (at least for us it was alot because it hadn't rained here in like 6 months) and because of the pump not flowing the SWG has not been running like we usually run it.
    Test Kit is a TF-100
    22,550
    You got a good test kit there!
    You're right, your FC is low for your CYA. You need to keep that up.
    My first step would be to run an OCLT to see if there's anything going on in the pool.
    There are a couple other places that tend to get obstructed. There is a little wire strainer where the water flows into the SWG. Unscrew the large plastic nut to get to it. Just hose it off. Also, where the hose from the pool enters the pump is another place that tends to get blocked.
    18'x48" Intex metal frame pool, 1600 Intex sand filer/pump combo, Intex SWCG.
    May 2011
    27
    I found the problem. It was clogged at the strainer at the pool lining. After the skimmer but before the pump. I should have known as I had to clean that once before but I didn't. I just happen to think about it today after I messed with the pump a bit and bam there it was. A big wad of hair and other ****. Didn't look like a lot but was taking about 1/3rd of my flow at least.
    I need to drain some water and then test but at least my issue is solved. Live and Learn!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Etouffee
    This exact problem is extremely common. Some else just had this the other day. The older Intex didnt have this feature, but I think they do it for liability reasons. In any event, I took the grids out of mine with a dremel. I let the pump stainer take care of that.
    Essential Links:
    I have the same issue and hate when the stuff floats up from that. Was wondering if I could soak cheesecloth in beeswax and form it inside the skimmer basket. Would that harm anything? Could it help to get the little stuff?
    AGP, POPUP, 3800GAL. SWG 2000 GPH pump. Over the wall skimmer. SE TX. NEWBIE
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Thank you! We just vacuumed our pool for the first time this morning and have been stumped about our flow issues all morning. It didn't occur to us to look inside the pool.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
