Results 1 to 7 of 7
Thread: I NEVER have 0 CC...
    Using FAS/DPD...
    15,000 gal plaster in ground.
    CYA: 30
    Pool is largely in the shade, and often covered with a solar cover, so I am usually adding just a few cups of bleech... keeping my FC at a steady 5.
    Water is always stable as a rock. A few glugs of acid a week keep the pH right in line.
    BBB is wonderful... Pool just about takes care of itself.
    The only thing is that my CC is NEVER 0.
    After calculating my FC, I put my 5 drops of 0003 in, and it ALWAYS turns a light shade of pink, which is disolved with a single drop of 871.
    Nothing to worry about I know... Was just wondering if anyone else experiences similar.
    Feb 2008
    Denton, TX
    5,061
    Re: I NEVER have 0 CC...
    It is normal to have some CC in the water. That just tells you that your chlorine is doing its job. When you need to address the CC is only when it is > 0.5 ppm. Less than that is ok and requires no further worry or treatment.
    May 2011
    Clearwater, FL.
    446
    Your good as long as you don't over 1 drop on the test to get back to clear.
    Mine sometimes uses 1 drop, other times no pink! It just depends a lot on weather, sun, bather load, pump running time and other things that might get in the pool from the wind blowing.
    I never need 2 drops, (TF-100 kit) so that proves to me I'm good!
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Jun 2011
    Norfolk, UK
    22
    Very normal in a covered pool. If I leave my pool cover on for any extended period of time the CC can rise quite a bit, which I used to shock for. A sunny morning (rare in the UK) normally brings it back down again without shocking. Just part of the getting to know your own pool process.
    32x16 -16,500 gallon plaster pool with connected spa and spillover, Hayward RS 1 HP pump, 2 Hayward Cartridge filters. 10 hours of direct sun a day and a first time pool owner!!
    22,549
    If you wanted to you could use a 25ml sample and run the tests. Each drop is .2 instead of .5 so you'd know if it's actually lower than .5.
    Sep 2010
    SC Lowcountry
    54
    I'm about 75% of the time no CC, and <.5 the other. I keep my FC about where you do (4-6), and the CC comes and goes without reason, so I don't worry about it. One less thing to think about right?
    Viking Laguna 14K IG , Smart Pure SWCG, SwimClear C5520 Cartridge Filter, TriStar 1.5HP, SmartControl PLP4 controller.
    Mar 2007
    Coastalish 'down easter'
    4,160
    While I fully agree with the above responses, do you brush or vacuum the 'low circulation' areas regularly? If the pool has dropped to ~ 0 fc at any time this season, algae might have taken hold, and once it does, a couple ppm chlorine isn't going to kill it in the 'low flow' spots
    Luv& Luk
    -Ted
