Results 1 to 10 of 10
Thread: In Line vs Parallel Solar Panels
    New Brunswick Canada
    819
    Hello All:
    A snowy back yard has gotten me to thinking about solar heating for pool next summer. In the attached file you can see my current set up and my proposed new set up. Will this be more effecient?
    What do you all think?
    Rik
    Oct 2007
    Valrico, FL
    542
    I believe that you really have to pipe the panels in parellel. A single panel can only handle about 3 to 5 gpm. So connecting them in parellel allows for more flow through the solar array.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    You get the most heat transferred into the water when running in parallel, which is your lower diagram (which you labeled in-line).
    819
    Thanks Jason, I knew I had it right, just wasnt aware which was which. So even though the panels are made to run up an down individually you would run them like diagram 2?
    Rik
    Yes, the lower diagram. You want the water entering the panel to be as cold as possible, the larger the temperature difference the more heat is transfered. If the water has already gone through one panel it will be warmer, and thus the second panel in a series hookup will be less efficient. To avoid that you want to have water directly from the pool feed to each panel. This is also good for the reason dschlic1 mentioned, the designed flow rate of the panels is fairly low. You want as much water going through the panels as possible, so every panel should get it's own flow (unless you have a *really* large number of panels).
    The panels are intentionally designed to work either way. There are situations where it is impractical to plumb both ends of the panel, so they provide a loopback mode, which makes it possible to make all plumbing connections on one end. That mode is less efficient, but required in rare cases.
    mas985's Avatar
    Pleasanton, CA
    11,741
    One modification I would make to diagram 2, make sure you should feed water into the bottom of the panels and not the tops. It makes priming the panels easier and better for heat flow.
    Mark
    819
    Thanks Jason and Mark:
    I will now change the way my panels are set up.
    Much appreciated!
    Rik
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I have mine run parallel however, I have each one piped in and out from one main back to one main, but different from yours.
    Ours has a main with a simultaneous split to each panel intake and the outles from each one simultaneously enters the single pipe, rather than in sucession as you have it. I don't know if its better or worse or no difference, but each panel gets the same amount of water pressure that way, rather than the last panel on the sucesssion getting less.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Mar 2007
    San Rafael, CA USA
    12,082
    The bottom diagram in the earlier post that showed the parallel panels will also have equalized flow rates in all panels due to the extra loop since the water flows in at one end of panels (top right in the diagram) and out the other end (lower left) so the path length for the water is the same regardless of which panel the water flows through. This ensures that the pressure difference between the top and bottom of each panel is the same for all panels so that makes the flow rates the same which is what is important. The fact that the pressure at the same point in each panel is different is irrelevant. All that matters for the flow rate is the difference in pressure between the top and bottom of each panel (and this difference is equal for all panels).
    Richard
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Good to know, thanks Richard.
