Results 1 to 9 of 9
Thread: More test numbers
    More test numbers
    I have my first test numbers, but I need help knowing what I need to do now, what to add, etc.
    FC 1.5
    CC 1
    TC 2.5
    pH 7
    T/A 70
    CH 60
    CYA 65
    Doughboy 18x38 AGP buried 2' deep. 18,400 gal. Hayward Power Flo Matrix. Hayward Pro Series High Rate Sand Filter. TF-100 test kit.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: First test numbers
    Your CC is greater than .5, so you need to shock your pool. See instructions in Pool School.
    Also, I suggest you get your pH to at least 7.2 ish before shocking.
    Post back with any q's.
    You're done SLAMing when:
    More test numbers
    Today's test:
    FC 1.5
    CC .5
    TC 2
    pH 7.2
    T/A 70
    CYA 60
    Not too shabby considering we had a 25 person party all day Saturday.
    I used the pool calc and it recommends the following:
    185oz bleach
    40oz Borax
    91 oz baking soda
    Sound right?
    Also, how do you add the borax and baking soda? Mixed up in water poured in front of the jet? Dumped into the skimmer? Or what?
    Thanks again for the advice. This method ROCKS!
    Also, the testing only took me 15 minutes this time. The first time it took over an hour.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: More test numbers
    You don't need to adjust pH or TA. Just add bleach
    Since you dropped below the min for your CYA, I suggest you add to the high side of your maintenance level.
    Awesome! Thanks. I will do just that.
    Another question: when you add your bleach, do you see tiny whirlpools develop on the water surface as it gets sucked down, or am I adding it too fast?
    Mar 2011
    Orlando, FL
    12
    Pour the bleach it slowly in fron of the return with the pump running - not in the skimmer.
    Viking Pools Freeport 12' x 25' Fiberglass 6000 Gallon Screened - Hayward Pro-Grid Vertical D.E. Filter DE2420 Hayward Superpump 1HP - Zodiac Pacer Cleaner - Pool Pilot Digital - TF-100 test kit - Central Florida Thanks to TFP Pool School, SWCG and the Pool Calculator, taking care of the pool is easy!
    I did pour it in front of the return, not in the skimmer. Apparently the whirlpools are not limited to when I add bleach. They happen all the time when the pump is on high.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    That is normal, it depends on how the return is pointed. I get them on low speed when adding bleach as well.
    Love TFP? Become a
    TFP Supporter!
