Results 1 to 8 of 8
Thread: Praise the lord and pass the ammunition! The forum is back!
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Was it down for a reason?
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Re: Praise the lord and pass the ammunition! The forum is b
    I'm currently investigating what happened. The database slowed way way way down, so that thing which should have taken fractions of a second were taking several minutes. However, I don't yet know what caused the problem.
    Mar 2007
    San Rafael, CA USA
    12,082
    The forum was down briefly again around 10 minutes or so ago. First it gave an SQL error saying there were too many connections. Then it came to the TFP home page saying the site was down and to try again in a few minutes. After a few 5 minutes, the site was back up.
    chem geek, thanks for the update. I still haven't been able to pin down exactly what is happening.
    22,551
    Just as reinforcement I got the same error Richard did. Must have been about 8:30 central.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Yeah, things got 'flucky' last night, but I figured that one of the mods finally realized that I don't know anything a bout pools, I've never seen nor even swam in one and pulled the plug on me (but I do stay at Holiday Inn Express often )
    Luv& Luk
    -Ted
    I found something and fixed it, though I'm not at all sure it was the real problem. Hopefully this will prevent these symptoms from repeating.
    May 2009
    Seminole, FL
    71
    Uhhh.. Where's the ammo?
    ~13000 inground plaster
    150sq Ft Cartridge Filter
