Thread: pool fill level
    May 2011
    Barrie, Ontario, Canada
    28
    pool fill level
    dumb question for anyone who has a pool like this.
    Bestway 18' x 48" (exact same as the intex steel frame pools)
    http://www.sears.ca/product/bestway-...00763193-11908
    I was noticing last night that my water level is nowhere near what it shows in the picture (not that I should go by the picture). The water is only about 1" above the return, and the instructions just show a picture of where to fill it, which is not a very good illustration, it just a rectangle with a wavy line through it..
    So if anyone who has this type of pool could enlighten me on what the maximum fill level.
    Cheers
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: pool fill level
    I've seen them filled to the cutouts or just below...no problems.
    Essential Links:
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: pool fill level
    Splash out is far less when the pool is 1-2" below the top of the fake tile pattern. Much much less than when it's higher so we're keeping it low this year. We also used pool noodles cut to the size of the cutouts and zip tied on to help block some of the splash out. They seem to work ok, but I think the lower water level is more effective.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
