Thread: Hayward Perflex DE Pool Filter leaking
    Hey guys, longtime lurker, but new member. I am having a bit of an issue with my pool filter. There is a leak right where the backwash pipe connects to the filter. I was wondering if this is a fix I can repair myself by emptying the filter, pulling out the pipe and refitting it? I am a new pool owner and thanks to your site maintain a crystal clear pool. I have had no problems until I noticed the leak yesterday. I am at work right now so can't post a pic, but I can when I get home tonight. I have caulked it with silicone to stop the leak while the filter is off, but while it is on some water leaks due to the pressure.
    Ritz
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,234
    Re: Hayward Perflex DE Pool Filter leaking
    As long as there is not a crack in the filter housing you should be able to fix it without too much difficulty. Pictures would be great!
    Love TFP? Become a
    TFP Supporter!
    22,400
    We need pictures.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    I usually don't bother messing with backwash line leaks (you're dumping the water anyway - who cares where it goes )
    If the problem persists when you are running the pool on 'filter', then you've got a valve (multi) issue, which should be addressed.
    The good folks here will help you with your issue
    Luv& Luk
    -Ted
    Oct 2010
    Georgia
    317
    Ritz
    Not sure which specific model you have, but most of the Hayward Perflex filters have a ball valve that threads into the backwash port at the base of the filter. You should be able to loosen the valve, add some thread seal tape and retighten to stop the leak
    If the ball valve itself is leaking, you should be able to replace it for less than $35.
    No multi-port on these models so you definitely need to repair the leak.
    PSG
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
