Results 1 to 9 of 9
Thread: Question about balance - pH / TA and CH
    FC - 7
    CYA - 50
    pH - 7
    TA - 140
    CH - 70
    I originally had a TA of 220 and a ph of about 8. I've added MA and dropped my pH and TA. I've been aireating but my pH hasn't really risen any. By the pool cal it says I need 15lbs of Borax. is this correct or is there a better way, like just continuing to let it airate. I don't want to drive my TA back up and be back where I started.
    Also, my liner is vinyl but I was wondering if I should try to get my calcium up a bit. Pool calc says 20 lbs of Cacl to get it up to 175.
    My pool is a 33'x52" AG but the actual useable meas is 32'W x 46"D
    33' x 54" Round AG - 150lb Clearwater High Flow sand filter - 1.5 hp two peed Hayward pump - TF-100 Test Kit - 1 clear clean pool thanks to TFP and BBB - 1 soggy wife and 3 water logged boys. Next up, THE deck!
    All of the above now in wreckage, hauled for scrap...and to wrap hunting blinds.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Re: Question about balance - pH / TA and CH
    What are you using to test the water?
    Don't worry about the calcium, you don't need it. To raise the pH you would need 15 pounds of borax, but that is only 3 boxes, or you can continue to aerate. If you don't have a fountain or aerator, make sure the return is pointed up to break the surface of the water. With a TA of 140 you should not have any problem bringing up pH by aerating.
    Love TFP? Become a
    TFP Supporter!
    30,431
    Welcome to the forum!
    It could be just taking longer than you expected. The more bubbles you can produce, the faster the process will go. YOu do not say how you are aerating but it seems like you're not making enough bubbles.
    Skip the Borax for now and continue to aerate.
    I probably am trying to rush it. All I have to aerate is the return which I have pointed up to the top of the the water......and kids splashing around. I'll let it be for a couple days and see where it goes.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    I'd aerate more. You can search the forum for homemade aerators and get some ideas. Some people have even used a submersible pump and a lawn sprinkler in the pool.
    If you're using any trichlor tabs, that will lower your pH. You should be using mostly bleach or liquid chlorine.
    Support the site
    Only chems I've used have been 6% bleach from Fred's, granular stabilizer, and muratic acid to drop the pH and TA. I have two boxes of Borax but I haven't even opened them. I'll do a search for the homemade aerators.
    Yep, I was rushing it. pH rose to 7.8 by dark today. TA still at 140.
    I'm sure you all have done the #'s, but I did the math on cost of bleach/ppm rise in Chlorine vs cost of 48% cal hypo/ppm rise. It's costing me about .65/ppm for bleach and it WAS costing me 1.23/ppm for 48% cal hypo pucks. Wish I could find the 12% you all talk about getting in returnable containers. I called our one and only local pool store today and the guy said "huh, bleach....liquid chlorine......uhhh no all we have is shock powder and chlorine tablets". I didn't even bother to explain it to him.
    Richard320's Avatar
    Jan 2010
    19,051
    Quote Originally Posted by stack_climber
    Keep your eyes open. When you see a pool service truck, you'll probably see yellow and orange plastic crates in the back, quite similar to milk crates but solid, in back. If you do, ask him where he buys it.
