Thread: plaster chipping
    plaster chipping
    I just did an acid wash for my pool and add new water last month. Few days later, the plaster on the step inside the pool start to chip, the chipped area (surface )is getting bigger and is very very rough. What should i do to have a smooth surface
    Butterfly's Avatar
    South Carolina
    10,045
    Re: plaster chipping
    Welcome to the forum
    Can you post a pic?
    How old is your pool?
    It would be helpful if you addedd your pool & equipment specs in your sig.
    Go to User Control Panel (top left under TFP logo), select Profile & then Edit Sig.
    You're done SLAMing when:
