Thread: Removing stain from built in ladder
    I have a vinyl liner pool with a recessed white ladder and corner steps. Every year they become yellow. I use Jack's Magic The Step Stuff on the steps with great results. The problem is, I can't use it on the recessed built in ladder in the deep end because the product uses gravity to let the liquid and granular reagents settle. Any good ideas on how to get the ladder clean? Area there any good products that come with an applicator that can be applied directly to the surface? Appreciate any help.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,375
    Re: Removing stain from built in ladder
    You might try using a mr clean magic eraser and see how that does.
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP!
    glesniak's Avatar
    Jun 2011
    Fuquay Varina, North Carolina
    10
    Does your recessed ladder have removable trim pieces? Mine have 1 horizontal and 2 vertical plastic strips that snap in place to cover the screws which hold the liner in place. I removed the trim pieces, held a rectangle of heavy plastic over the ladder and snapped the trim back in place. This created a pocket full of pool water isolating the ladder steps from the rest of the pool. I then added citric acid to the pocket and let it sit for an hours or so. The yellow stains were gone.
    George
    George
    17.5k gallon, 16.5' X 40' IG vinyl liner pool, Hayward 1HP Super Pump, Hayward S244T sand filter, Jandy Legacy Lxi NG heater, Rainbow chlorine feeder as back-up to BBB, WaterTech PoolBlaster Pro 900 hand-held vacuum, TF100
