Results 1 to 9 of 9
Thread: Vacation tips and tricks
    Mar 2011
    Lower Bucks County,PA
    65
    Gotta go out of town again ,this time vaca. No one at all to watch pool. Read somewhere on here (just can't find it again) about filling bottle with liquid Cl and letting it weep into pool. Anyone do this or how bout some other idea's you folk's use while your away. Just don't want to go back to pucks if there is anything else i can do. Thanks
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Re: Vacation tips and tricks
    When I go away for extended periods of time, I bring my pool water up to shock level, close the cover and come home to a clean, clear, sparkly pool. My pump is on a timer.
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,388
    If you can run the pump on a timer and you don't get a lot of falling debris that blocks the skimmer, then bringing the pool to shock level is the best option. Some have used the open bleach bottle but if you don't set it up right you could get bleaching of your liner around where the bottle sits.
    Love TFP? Become a
    TFP Supporter!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I wouldn't do the bleach bottle without experimenting first. If you did it, you could tether it with a weight...like a bowie. Say somewhere close to a return jet. Shocking sounds the easiest though.
    Essential Links:
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Pucks in a floater?
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Sep 2009
    Greentown, IN
    914
    If your cya is not too high you can use pucks for short term... Not sure if pump needs to be running continually for this, someone else would have to tell you as I've never used them.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Use the pool calculator to find out what X number of pucks will do to the CYA. It may not be that bad. And go to shock level as you leave.
    Jun 2008
    Marana, AZ
    347
    I've always used pucks when I'm unable to take care of the pool for a few days, ie. vacations. As long as your CYA is low to good, and you don't use them for more than a week or so, you should be okay.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Mar 2011
    65
    Results from vac-brought pool up to shock level, covered with new 12 mil blue cover(50% cheaper from the folks at solarcovers.com , recieved in three days, thanks guy's) turned off pump and left. Ten day's and was little worried when i peeled back the cover but was blown away on how clear it was . Tested out at 3.5 cl which was still on my low end . Quick brush from settlement -24hr run and back to normal. Thanks for the imput guy's, this is definitly the way to go when away from home.
    Hi-Flo 2sp 1hp pump
