Results 1 to 12 of 12
Thread: Solaxx PH Tek Acid Feeder
    RCDuck's Avatar
    Jun 2008
    TEXAS
    11
    Anyone have any experience with this system: http://www.solaxx.com/ph_tek.php
    I've read several of the posts regarding acid feeding here but have not come across any mention of this system. The systems I have read about here include Simpool, Stenner systems, and a more dyi system. The solaxx system looks to be an all-in-one system with PH sensor, pump, and tank which I don't think the other systems have. The downside to the other systems as far as I have been able to determine are:
    Simpool: Difficult to get in the US? No tank included?
    Stenner: Components need to be custom selected to match my needs and runs on timer system rather than sensor?
    DYI: More than I care to mess with.
    If any of these assumptions above are incorrect please correct my thinking. How much would a Stenner pump/tank system or the Simpool system cost compared to this system? I think the Solaxx system can be purchased for around $600.
    26,000 IG Pool (Gunite w/Premix Marbeltite), Jandy Stealth 2 speed pump, Jandy CL460 Cartridge, Jandy SWG, Nature2 (Disabled), Ultrapure Ozone, Polaris Cleaner, Jandy PDA controller
    22,468
    Re: Solaxx PH Tek Acid Feeder
    It looks like a good system and if it's close to $600 it isn't a bad price. A stenner pump with the tank together is about $350.
    Mar 2009
    Glendora, California
    169
    I was also looking into this unit, sharing some info I discovered in my research. The unit comes with 1.5" clamps, 2" are available at additional cost. The manual specifies fume free Sulfuric Acid be used. I e mailed Solaxx support about replacement tubes and they are available but was told not needed if you use Sulfuric Acid. They said the only time they had to replace tubes was "due to a incorrect installation allowing fumes from muriatic acid to damage the pump hose and roller". Reading up on Sulfuric, it seems to cost more and require more to lower PH. So now I am looking at the CAT system.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    Apr 2011
    Maryland
    18
    I have been using one for 2yrs with Mur-acid cut 50/50 it works great for me, set it and forget it.
    18000 gal Gunite free form
    Jandy 1 HP pump
    Jandy DEV 48 filter
    Raypak 400 heater
    Goldline Proligic SWCG
    Solaxx chemical feeder
    Dolphin Deluxe 4
    We do not recommend using sulfuric acid in a swimming pool. Sulfuric acid adds sulfates (bad) and costs more (bad). Of course, it doesn't fume the way muriatic acid does (good).
    Mar 2009
    169
    Thanks chucklh and Jason. Chuck, that's good news, what strength MA are you using? Looks like I'm going to go Solaxx after all.
    Solaxx Ph-Tek
    Apr 2011
    Maryland
    18
    I use the standaard 31% cut 50/50 with water and easy to install........
    Jandy 1 HP pump
    Jandy DEV 48 filter
    Raypak 400 heater
    Dolphin Deluxe 4
    Mar 2009
    169
    I'm closing in on a year with the Solaxx and so far it's great. I mix water and MA in a bucket to about 50/50 proportions, I let it sit so the fumes clear and then pour it into the Solaxx. I calibrate the sensor probe about every 1.5 months, calibration is quick and easy. I had an out of calibration scenario with the pump it was reading 7.8 and actual was 7.2, still within TFP numbers, calibrated the sensor and all was well. I'm still on the original sensor, I believe they are supposed to last 12-18 months and if I recall Solaxx quoted 100 - 150 for a replacement. I plan to try a lower cost BNC PH Probe from ebay when it comes time to replace. I do find my TA is now low and out of TFP spec so I need to address that. My SWG is going into year 4 and the salt reading matches my drop test and I give credit to the Solaxx pump for that. So far I am happy with it.
    Solaxx Ph-Tek
    22,468
    That's a good report. We like real world experience.
    Mar 2009
    169
    Well it's been a few more years, I get occasional PM's about the unit and want to give everyone the latest. According to my records I did replace the PH probe in October of 2013, I recall I bough it again from Solaxx. When it arrived, the cable was much shorter than the original probe, for additional cost Solaxx had an extension. ThermoWorks.Com has a unit called the 8000 PH meter On the page you will find an Electrodes tab, the first one listed looks like it could work and I plan to give this one a try when the time comes. If someone else gives it a try, please let us know how it turned out.
    Per my records I last calibrated the probe 04/14. The unit is set to hold PH at 7.6 and testing shows an actual of 7.2. I have a SWG so this is low for my pool. So in almost 2 years of no calibration I drifted out of recommended settings for a SWG. My cell showed light scale only once and I was able to clean it with just a hose and wooden skewer. Majority of the time it checks out clean. Other than the probe, I have not replaced anything else. I continue to feed it with MA and water mixed at 50/50 in a bucket then poured into the unit after the fumes have dissipated. I am still happy with the unit.
    Solaxx Ph-Tek
    Resurrected necro thread!
    I just got my pHTek and I can not get the fitting to stop leaking! Any ideas?
    22,000 Gunite, Cart Filter, Aquarite SWG
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    961
    Well I apologise for not reading the above old posts, but i know lots about fittings.
    What kind of fitting is it?
    What is the sealing system? Threads, o ring, flanged?
    How long has it been in use?
    Is it leaking pool water, acid, or both?
    Leaking a lot or a little?
    Intex 24' x 52" Closed for 2017/18 Winter
    2 Main Drains, hard lined 1.25" and 1.5" PVC
    1/2 HP Intex Pump w/ 42 lb 13" Sand Filter
    TF-50 and Taylor 2006 Test Kits
