Results 1 to 13 of 13
Thread: Generic Bleach vs Chloine
    Dec 2010
    Central California
    15
    New pool owner question...
    When I do the math....the 10% chlorine I can get at HD is a better value than generic 5% bleach. If only because I need twice as much as the 5% stuff.
    Am I missing something here?
    30'x14' (12.5K Gallon) Viking Carmel - Saphire Blue Crystite Finish
    Jandy Stealth Pump - 2 Speed 1.0 HP
    Jandy Cartridge Filter - 340 sq. ft.
    Fiberstars 6004 Metal Halide Light with 4-Position Color Wheel
    Polaris 280
    Maintained with BBB
    bpeunic's Avatar
    Jun 2011
    Niagara Falls, NY
    14
    Re: Generic Bleach vs Chloine
    are you comparing Liquid Bleaches? Are they both Liquid?
    go check out the pool school, it will be helpful.
    Brian
    22,000 gallon in ground Gunite pool(Beauty Pool, 22 yrs old)) with built in hot tub,
    Hayward DE75 Filer and Pump, Haywood Heater, AutoMatic pool timer, BBB Method folower.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If the price is right, then it can be a better deal, but it is the exact same chemical. There is the upside of less packaging...one vs two bottles, but that is it. I would only add that if you were buying in off season, or near the end of season, it might not be as fresh. This time of year I imagine it is though.
    Edit: I was assuming you meant liquid/liquid comparison.
    Essential Links:
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Are you sure your generic bleach is 5%? The brand I use is 6%. At 99 cents for 94 oz, buying the generic brand of bleach at 6% is still a better buy for me, even if I do have to recycle a lot.
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
    I did the math on mine yesterday and it cost me .65 to raise Chl 1ppm using bleach (2.50 for 1.46 gal) where using 48% cal hypo WAS costing me 1.30 per ppm.
    33' x 54" Round AG - 150lb Clearwater High Flow sand filter - 1.5 hp two peed Hayward pump - TF-100 Test Kit - 1 clear clean pool thanks to TFP and BBB - 1 soggy wife and 3 water logged boys. Next up, THE deck!
    All of the above now in wreckage, hauled for scrap...and to wrap hunting blinds.
    Mar 2010
    Spring, TX
    1,082
    I have found for me the generic does not work as well as brand chlorox.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    "Generic" is a broad array of products.
    Great Value 6% (sold in walmart for $2.54/1.42gal) works great. While a "Generic" sold at a dollar type/bargain store may in fact only be 3% bleach and perhaps well past it's manufacturing date.
    Net...look at the label. Unless it states 6% sodium hypochlorite, you can't be sure what you are comparing it to
    Mar 2010
    Spring, TX
    1,082
    The generic I get is 6% per the label. Just does not seem to work as well as the chlorox for me.
    Jul 2010
    Mickleton, NJ
    229
    I just bought Target's Up and Up store brand, 6% it was signicantly cheaper than Clorox, anyone else use this?
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by mynewpool
    Hey there,
    Just curious, how much beeter does the Chlorox work for you. Never have tried it, as the "cheapos" always seemed to do just fine.
    Essential Links:
    My experience is that it has more to do with the particular store than the brand of bleach. Bleach that has been sitting around for months and months loses strength. Some stores are much better than others at keeping their stock fresh.
    Quote Originally Posted by melissab
    This is my second season of using Target brand of bleach and have not had any problems.
    Carlotta (aka Clodda)
    Oval AGP 18x33x54 18,000 gal.
    2hp Hayward Pump
    Sand filter
    BBB Method
    Jug Dumper
    I bought a gallon of 10% for around $4. K-Mart, think I'm going to stock up.
    Keith
    Intex 15' x 48" AGP (5300 gallons)
    Intex 2,100-Gallon Sand Filter Pump
    Central Mo
