- May 31, 2011
- 246
- Plaster
- Pentair Intellichlor IC-60
Hi all,
The 3 way valve on my return is leaking a bit from the inlet joint and it is jetting stiffer to move. It wont even go all the way to spa side anymore.
Which brand of 3 way valve would you recommend to replace it with? Is Jandy a good choice?
Also the connector from the heater outlet to the PVC has started dripping when i run the pump on high. I plan to put new 2" PVC pipe from the heater outlet to the 3 way valve as i will be installing a new 3 way valve anyway.
Any suggestions or warnings before i dismantle the connection to replace the seal? Is it a complicated procedure?Should I hire a plumber instead? I am good with piping, etc and have designed and installed sprinkler systems before.
Any help would be appreciated.
Thanks!
Thanks!
