Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: Need to Always Backwash
    Jun 2011
    Ste-Marthe-sur-le-Lac, Quebec
    38
    Hi everyone,
    Here is my problem, I have a Pentair TA60 clearpro filter a summit heater (sum3 titanium) and a Pentair superflow pump.
    My problem is that after doing a backwash my pressure is around 25 psi.
    When it its around 27 psi, my heater stop working telling me not enough FLOW as message.
    So now to heat the pool I need to backwash once or twice a day......
    Could someone help me, is 25 psi normal pressure or is it to high, another thing I've notice is that if I close my bottom drain and keep only skimmer the pressure goes down to 22 psi.
    Thanks.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Need to Always Backwash
    Hi, welcome to TFP! I have a few questions for you. Is this a new problem, or has this been happening for some time? How long do you backwash? How much does the pressure drop after backwashing?
    Love TFP? Become a
    TFP Supporter!
    Jun 2011
    38
    Hi thanks for quick reply,
    My pool is new from last year, same things last year.
    Pressure drops only from around 2-3 psi after the backwash (around 2 minutes), because I do them so often so I can use the heater, otherwise heater stop with flow message on display.
    I tried to remove around 30 pounds of sand (thinking pressure would drop more in filter so my heather would run longer) but it is still the same
    22,549
    List all your equipment and pool info for us.
    Pool type and size.
    Pump size.
    What size eyeball(s) do you have.
    What heater do you have.
    etc.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Welcome to TFP!
    I'd suggest you run your filter set to recirculate to see if the problem is with the filter or the plumbing. If the pressure is substantially lower on recirulate than it is on filter, make sure you are backwashing for at least 3 to 4 minutes.
    Jun 2011
    38
    Ok on recirculate, my filter is running at 15 psi, wich is great!
    Here is my equipment:
    Filter: pentair, tagelus clearpro technology ta60
    Pump: pentair, superflo 1 1/2 hp
    Heather: summit sum 3
    Thanks for your help!
    I will upload a picture of setup
    Jul 2009
    Houston, Texas
    9,380
    Try a good, long backwash then rinse for about 2 minutes and see if that helps.
    Love TFP? Become a
    TFP Supporter!
    Jun 2011
    38
    Ok, i did 4 minute backwash.
    If water out direct to pool from drain and skimmer, pressure 22
    If water out direct to pool from skimmer, pressuer 19
    If water out direct to pool from drain, pressure 21
    If water out to pool by heater from drain and skimmer, pressure 24.5
    If water out to pool by heater from skimmer, pressure 22
    If water out to pool by heater from drain, pressure 23.5
    If i leave water to pool by heater from drain and skimmer, tomorrow at noon I will have flow message on my heater.
    Any other info I could give you guys?
    Thanks.
    Jun 2011
    38
    Hi everyone, so I still needed to backwash again today
    I was thinking of changing my laterals in my sand filter to normal ones instead of the ClearFlow ones.....
    Do you guys think my pressure (Flow) will be better with normal Lateral?
    Thanks to all of you for your help.
    22,549
    I'm not sure what the normal pressure drop across the filter with the Clearpro is but it doesn't seem too high.
    Did you ever figure out what size eyeball you have?
    Try taking the eyeball fitting out of the return and see if that helps the pressure and flow.
    30,419
    rejeanc,
    What does your water look like? It's important to eliminate ANY water quality issues...your filter might REALLY be doing what it's supposed to and the gauge is faulty.
    Jun 2011
    38
    My water is great.
    I really think it's the ClearPro laterals that causes the pressure to be so high, The flow is not very strong in the pool so I'm sure it's not a faulty gauge.
    My real problem Is because I need to backwash every day (other wise flow waring on heather), it's the second time this season that I'm adding salt and alcanality, I'm wasting a lot of water because of the backwashing...
    Does anyone have experience with ClearPro technology from pentair?
    Thanks to all!
    22,549
    How about posting a set of test results and how you got them?
    The fact that your pressure is rising 2 psi per day is an indication that it's filtering something.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I agree Dave!
    Jun 2011
    38
    Thanks to all for your help.
    When I remove the eyeball I still have the same issue.
    Does anyone have any experience with ClearPro technology from pentair?
    Thanks again.
    Jul 2009
    Houston, Texas
    9,380
    You can contact a Pentair tech directly at Pool fyi Monday through Friday. Usually you will get a same day response.
    Love TFP? Become a
    TFP Supporter!
    Dec 2008
    82
    need those test results as requested. You're filtering something out. These filters aren't much different than a normal filter. If you changed the laterals the problem would probably go away, but only because you would not be filtering as well.
    Jun 2011
    38
    What kind of test results?
    These are no good?
    Thanks.
    Dec 2008
    82
    Looks like Bama is asking for water chemistry results.
  20. Back To Top    #20
    Butterfly's Avatar
    South Carolina
    10,045
    Looking for water test results (and how you got them). We need:
    FC
    CC
    pH
    TA
    CH
    CYA
    This will help eliminate water quality issues.
    ETA: Cadillac typed faster
    You're done SLAMing when:
