Thread: Black algae question
    Jun 2011
    TUCSON, AZ
    3
    I have a salt water pool with a Pebble Tec finish. I have to small areas of what I think is Black Algae.
    Do any products work? What should I do? How do I know for sure if it is Black Algae. It does look like it in the picture that I have seen.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Black algae question
    Hi, welcome to TFP! Please read through Pool School and pay particular attention to the sections how to shock your pool and
    defeating algae. Also if you could post a current set of test results that would be great!
    Try and scrape up some of the spot and rub it on the back of a white business card. If the smear is dark green then you have black algae. If that is the case you will need to scrub the spots with a wire pool brush and keep the pool at shock level until the algae is gone.
    If you are not able to scrap any of the spot off or it doesn't leave a smear then try holding a plain, un-coated vitamin C tablet on the spot. If the spot fades then you have metal staining, which requires a different treatment.
    Post back and let us know what you find out and we can proceed from there.
    Love TFP? Become a
    TFP Supporter!
    Butterfly's Avatar
    South Carolina
    10,045
    You can also try rubbing the area with a trichlor puck to see if it lightens any.
    Can you post a pic for us?
    Welcome to the forum
    You're done SLAMing when:
    Jun 2011
    TUCSON, AZ
    3
    Quote Originally Posted by Butterfly
    Thank You Butterfly.
    What is a trichlor puck?
    I will try to send a pic later after it gets light. I assume you mean of the black spots or of the pool itself. I will send both.
    Butterfly's Avatar
    South Carolina
    10,045
    A trichlor puck is a stabilized form of chlorine, formed/shaped into something of a disk shape.
    I think they sell them as 'singles' (you don't want a bucket full) at WallyWorld?
    And yes, rub the black spots, sorry about that
    Maybe you have a pool buddy that could give you just one puck to try?
    Jun 2011
    TUCSON, AZ
    3
    I tried sending picture but my file is 1.5 MB your limit is 250K
