Thread: Scaling?
    Scaling?
    Does this look like scaling? It's also on the blue plaster as well. It won't brush off. Please help!!!
    Fc 3
    Ta 95
    Ph 7.2 after acid back up to 7.9 by the end of the week
    Ch 230
    Cya 50
    Salt 3000
    Phosphates 100 per leslies test
    18,000 gal ig salt pool krystalkrete plaster 7x10 raised spa w/ 2 spillovers
    4x20 wet deck, waterfall, 17ft infinity edge, deck jets, nexxus lighting
    Jandy pumps & controls, Aquapalm PDA, 400k heater, Kleen Machine robot
    (6) 4x12 solar panels, clear solar cover
    Re: Scaling?
    Here is the picture
    Re: Scaling?
    No, your current test results are not suggestive of scaling problems. With the PH down around 7.2 you are getting close to having etching and pitting, though not quite there yet. Even with the PH up at 7.9, I would not expect any scaling.
    There will almost invariable be some calcium buildup on surfaces above the water line that get splashed regularly. If they get splashed and the water subsequently evaporates, any calcium (and salt) in the water will be left on the surface.
    Re: Scaling?
    So any idea what that would be in the pic or what product I should try to remove it ?
    30,414
    Re: Scaling?
    Maybe others can see it, but I can tell nothing from the pic....it's too small.
    Mar 2011
    Houston, Texas
    413
    Re: Scaling?
    I'd say be careful and look out for scaling, unless you are very confident in your CH test results. I have the same pH swing that you describe and two pool stores were telling me that my CH was in the mid 300's. When my TF-100 arrived my CH test said it was in the high 700's. I thought my test had to be wrong. Well, I developed scaling even though my average pH was probably around 7.5 or 7.6--it would go up to the high sevens or low eights for short periods of time and then down to 7.2 after I added MA. I plan to drain about half my pool to get my CH in the 400 range and to be careful to never let my pH go above 7.5--ever.
    [edit] And my other test results were/are similar to yours. My problem is a rising CH. We finally got rain today in Houston so it might help a bit.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
