Results 1 to 15 of 15
Thread: Muriatic acid
    Medic3's Avatar
    Jun 2011
    Missouri
    42
    Muriatic acid
    First I would like to state that I have found the information on this site extremely helpful. I now have a clean pool with very little problem due to following the information I have found on this site! Pool stores love me!
    Now I have a question I cannot find an answer for. I would like to know when muriatic acid is added to pool water, what happens to the acid. Is it used up? What is the resulting by-product. Or, What compounds that are left behind as a result of use. I have small children and this creates my concern, I want to know how safe is muriatic acid is. I know that muriatic acid lowers PH and TA (Yes I do know the procedure for lowering TA). I normally operate my AGP with a higher PH 7.8-8.0, high TA 240, and a high hardness of 340. Its my fill water from the well. I have been having a little trouble with scaling and would like to lower my PH and TA. Maybe! Thank you for the information on this site. I actually enjoy pool maintenance now .
    20,000 gal. 27' AGP
    Hayward 18" sand filter with 1 hp Hayward Matrix pump
    A convinced BBB user and TFP fan
    Re: Muriatic acid
    The acidity of the water depends on the pH. Once the acid is added and allowed to mix and circulate, the final pH of the water is what determines what is safe.
    There is no muriatic acid left circulating in the water. It is perfectly safe when used as directed. The only thing left over is a little bit of chloride, like from regular salt (sodium chloride).
    Note: Concentrated muriatic acid is dangerous and must be handled with care. Take precautions to avoid contact with skin or eyes. Always have a plan for accidents or spills before handling.
    Support the site
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,565
    Re: Muriatic acid
    As for the concern for the kiddos........I'll generally add 20 oz.s of acid at a time and jump in after 30 minutes after circulating.
    Re: Muriatic acid
    Muriatic acid is hydrogen and chlorine. When added to the water it forms H3O+ and Cl−. Essentially it increases the hydrogen ion level and adds chloride ions. In the very long run that usually ends up as hydrogen gas and salt, depending on what else is added to the water.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Muriatic acid
    I don't think one sees hydrogen gas. Usually one is adding acid to compensate for carbon dioxide outgassing so the acid lowers the TA over time as well. So if one is adding baking soda to keep the TA from falling too much, then the net result is just a salt (sodium chloride) build-up. The hydrogen ends up becoming a part of water from carbonic acid when carbon dioxide outgasses.
    HCO3- ---> CO2(g) + OH-
    (add HCl) ---> H+ + Cl-
    (add NaHCO3) --> Na+ + HCO3-
    result is CO2(g) + H2O + Na+ + Cl-
    or carbon dioxide gas, water, and sodium chloride salt
    Medic3's Avatar
    Jun 2011
    Missouri
    42
    Re: Muriatic acid
    This is very interesting! So after adding muriatic acid to my pool, the only thing "leftover" is salt. I now feel more comfortable about lowering my PH and TA.
    Now what I find interesting is everything I add to my pool other than the CYA, seems to be some form of salt. The only chemicals I add to my water besides CYA is, chlorine and muriatic acid. Is this correct, am I basically performing water sanitation with salts? It appears to be safe to me.
    20,000 gal. 27' AGP
    30,402
    Re: Muriatic acid
    Why would you think it wasn't?
    Medic3's Avatar
    Jun 2011
    Missouri
    42
    Re: Muriatic acid
    Its just that muriatic acid is a strong acid and, I was concerned about having a pool full of "acid" after lowering TA.
    20,000 gal. 27' AGP
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Muriatic acid
    Yeah, HCl is strong, but you're only adding a few ounces to thousands of gallons of water - quite frankly the equivalent of a drop in a bucket.
    And stomach acid is partially HCl......your gut has a pH of about 2!
    Feb 2008
    Denton, TX
    5,061
    Re: Muriatic acid
    Pool water has lots of different components that in their pure and undiluted form, would be extremely dangerous. But in such dilute amounts, they exist to do us no harm and are actually beneficial. You can't really describe it as a "pool of acid" any more than you could call a glass of water as a glass full of hydrogen and oxygen, both of which are substances with significant hazards in their own elemental form.
    Muriatic acid
    People get caught up with associating "salt" with table salt. Salt is the product of any acid/base reaction (NaCl, KCl, CuSO4, etc...)
    5,000 Gal
    Cartridge filter
    Semi-AG
    AquaTrol-HP SWCG
    1 HP Pump
    Jun 2011
    Albuquerque, NM
    77
    Re: Muriatic acid
    Quote Originally Posted by Richard320
    Can I just say this made me laugh out loud.
    Yeah, but you wouldn't want to swim in your gut!
    Cindy
    4.8 K gallon AGP: sharkline opera 12'x17'x52"
    Sandpro 4511 sand filter and pump
    Re: Muriatic acid
    nor would you want to swim in any pool with a ph of 2
    Re: Muriatic acid
    DESPERATE: I have a question about Muriatic acid and pool water. What is the effect of adding Muriatic acid to Baquacil treated pool water that come from our own well water in north Florida where the well water comes out of lime rock and is highly calcium carrying as attested to film left on glasses, etc? Can Muratic acid be successfully added to Baquacil well water to adjust pH?
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Muriatic acid
    Yes you can use Muriatic Acid to lower the pH in a Baquacil/biguanide/PHMB pool. Regardless of pool type, you should add the acid slowly over a return flow with the pump running and should then lightly brush the side and bottom of the pool where you added the acid to ensure thorough mixing.
