Results 1 to 20 of 20
Thread: Combined Chlorine - I'm confused
    I have been using the BBB method for about 2 1/2 months now. I have the pool pretty well balanced (I think). Pool is DE filter, vinyl liner, 15,000 gallons. Pump turns over the pool in about 5 hours so I run it for 5 hours every day.
    FC 13
    CC 4
    TA 100
    PH 7.6
    CYA 45
    So, my CC was 2 this morning and the FC was 6. I added 260 ounces of Bleach (6%) and ran the filter for 5 hours. I expected the FC to go up like it did to 13. Was the CC supposed to go up too? I expected it to go down. I don't use anything anymore. I was using 3 inch pucks initially but ditched those.
    I just don't want to harm the pool by adding too much. Water clarity looks really good. No visible algae. Did have a little issue with staining but added some stuff to clear it up weeks ago. Now, I am supposed to add 3 ounces every other week to maintain. Sparkle Conquest is the name of the product.
    Should I be concerned about the CC number or will it go down?
    16x32 in ground, 4 to 6 ft, Hayward 1hp Super Pump, Hayward DE Filter (7lbs DE), Solar Cover
    Aug 2010
    Dallas, TX
    4,052
    Re: Combined Chlorine - I'm confused
    If I remember correctly, when you start killing organics, your CC will go up. I had the same thing happen to me. Continue all the way through the shock process, you certainly need to do so.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    The pool needs to be shocked. You'll want to maintain FC around 14-16ppm until cc is 0.5ppm or below, the water is clear and you can pass the overnight FC loss test.
    You are using the fas-dpd 10ml sample and counting each drop as 0.5ppm, correct?
    Yup. I am using the Taylor kit. I added so much bleach in an effort to shock. I was just concerned that the CC went up when I added the bleach. I just wanted to make sure that is normal.
    P.S. A little disappointed in Martin for not giving Jr enough room last race. Could have jumped to second but at least it did not hurt too much.
    Update: 7:30am - FC 10, CC 3.5.
    Update: added another 260 ounces of bleach at 10:30am. Will let the pump cycle for a while and take a reading in about an hour.
    Important to note I have NOT had the solar cover on at all this year so far.
    Update: I tested at 1pm with the following results.
    Calcium - 130
    TA - 110
    PH - 7.5
    FC - 15
    CC - 0
    CYA - 45
    Unless I'm crazy those results are dead perfect. Now, the magic questions. I will test again tomorrow to see how much FC I lose and if the CC is maintained at zero. I believe my maintain level of FC should be 6. If the CC holds at zero do I allow the FC to drop to that level? I also believe I should be adding about 60 to 62 ounces of bleach daily as my maintenance routine. Should I just be adding my maintain from here on even with the FC at 15?
    Thanks for the guidance!
    Those numbers look great. I would let TA come down over time, but that is trivial given you don't have a SWG or any water feature.
    Yes, if the water is clear, FC holds overnight, and CC is 0.5 or lower you can let the FC level come down to [edit]normal levels[/edit].
    There is no need to add chlorine when FC is already above 6 and you aren't shocking the pool.
    The amount of bleach you need to add each day will vary just a little depending on how much swimming is happening and the weather. More people swimming and hotter weather or storms usually mean you need to add more bleach.
    wow. come down to zero? I figured I would have to maintain around 6 according to the CYA chart. The TA and PH have been pretty steady. I have not added anything for those in weeks.
    Thanks!
    hawkeye's Avatar
    davenport,iowa
    118
    i dont think he meant to say let fc get down to zero though, im sure he will chime in to correct himself real soon..... 3-6 fc i guess is a real good range
    if my pool gets down to 2.5 or so im freakin out man! so i dump in 18 ounces so it bumps it up to bout 5.0 fc right where i like it, always keep it there in this range @ 3-6 when you get passed the overnight test......mike
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    Sigh, my fingers typing something other than what I am thinking. As hawkeye said, let FC come down to normal levels (4-8).
    hawkeye's Avatar
    davenport,iowa
    118
    also do yourself a favor go to the pool store and get yourself some 12.5 % chlorine, it is so much easier to use than cart full of bleach from walmart,and you dont have all these bottles to recycle what a pain it is to deal with them,you can but 2 or 3 cases of shock 12.5% and you will see how much better it is to use for your pool twice as strong as regular bleach trust me you will like, i love it when i go to the pool store and i walk up to the counter with cya,couple boxes of chlorine,and some replacement taylor regents and just look at the line of people sometimes with samples to get done ya "get done" is right!! lol i made a funny
    im glad to have found this site and have learned alot from all of you and my water has never looked better!..... thank you all mike
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Quote Originally Posted by blueshrt94
    Calcium - 130
    TA - 110
    PH - 7.5
    FC - 15
    CC - 0
    CYA - 45
    Just for clarification, won't you need to follow the instructions for an overnight FC loss test - which means testing the FC level tonight after the sun goes down and tomorrow morning before the sun comes up - to actually see if you are done with the shocking process? A test during the day and one the next day will not tell you what was lost to sun and what was lost to organics.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    Jun 2010
    San Antonio
    424
    Quote Originally Posted by aa62579
    Calcium - 130
    TA - 110
    PH - 7.5
    FC - 15
    CC - 0
    CYA - 45
    Yes he will.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    UGH! Spoke too soon. Just tested at about 10:15pm. FC is 11.5 and CC is back around 3. I don't get it.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    You should expect to lose FC during the day, but your CC indicates you are nt done shocking.
    ~~ Allison ~~
    Mar 2007
    San Rafael, CA USA
    12,082
    Something is odd to have the CC yo-yo like that. If you have a pool cover that isn't clear, keep it off during the day and let sunlight hit the pool. That can often help to get rid of the CC along with shocking. Check your filter pressure to see if it has risen and needs to be backwashed/cleaned.
    Jul 2010
    England, UK
    156
    3.0 seems like a lot of CC to appear out of nowhere.
    Did you run the test a second time? That's what I do when I get a weird test result.
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    When you are doing the FAS-DPD chlorine test, make sure the sample turns completely clear and stays that way while you are swirling it to mix for at least 15 seconds. Near the end of the test you can sometimes see the sample go clear for a moment and then go back to a pale pink as you continue mixing. If it only goes clear for a moment that doesn't count.
  20. Back To Top    #20
    Something must have been wrong last night. I did a test this morning at 10:30am. Been overcast with no real sun to speak of. Have not run the pump yet today. FC is 11 and CC is zero. Looks like I lost .5ppm of FC overnight. I have been a bit suspect of the stuff you use with the 2 dippers. I used a new one today. I'll give it another check tonight after I run the pump.
