Results 1 to 14 of 14
Thread: Help!!! grass growning through liner
    We have a above ground pool and we've notice grass growing through the liner last year. So this year we havbe to replace the liner and kill the grass can anyone help us in to what to treat the grass with to kill it from coming back..
    16,000 gallon in ground pool (pool built @1960)
    concrete with epoxy paint
    Sta Rite T240 Crystal Flo sand filter
    * Replaced sand with zeo sand Spring 2010
    1 hp single speed Dyna Glass pump installed 2006
    Added borates to pool spring 2011 per TFP instructions using Borax
    22,553
    Re: Help!!! grass growning through liner
    There are a few nutsedge killers. sedgehammer is one and Image. Whatever you use you need to follow the instructions and don't skimp. Soak the ground and then wet it in. Also I'd use the Gorilla Pad under it.
    Thanks were can you purchase that weed killer at? We did also purchase a pad this time.
    22,553
    Just search online for nutsedge killer and you'll find plenty. I think Tractor Supply has it if you have one close to you.
    We do thanks... One more question when using this stuff will it hurt if it gets on the pool liner?
    22,553
    It won't hurt it.
    Okay I've been to Tracker Supplies and Atwoods and no luck on the Sedgehammer or Image. So we purchased some weed killer in hoping it will help kill the nutgrass. I'm guessing that's what kind of grass it is..
    Nov 2010
    Calera, Al
    271
    Quote Originally Posted by emaksb
    Many weed killers will not kill nutsedge you need a good herbicide, I use image and get it at home depot.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    22,553
    It needs to specifically state that it will kill nutsedge.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    X2 On this. You might go to a local nursery to find it if no luck at home depot.or similar. If it doesnt list nutsedge, I know from experience it work.
    Essential Links:
    Okay I found the image at home depot and got the grass sprayed and it looks like it working. The pool guy came and installed a pad and new liner and the pool is on it's way to filling up. I've learned some interesting stuff off this web page and would like to try using these methods can someone point me in to the right direction on how to start after the pool is filled up....Thanks
    I've always use chemicals..
    22,553
    All you have to do is start reading Pool School, specifically the balancing parts. Also, don't be afraid to ask questions as they come up. You also want to get a good test kit. You can see the link in my sig to the best place to get one.
    Until I get a test kit what do I need to be doing?
    22,553
    Reading Pool School, Oh, and add 2ppm of chlorine in there each evening and enough CYA to get to about 30 ppm, once it gets filled. Post back if you need instructions on how to use the Pool Calc to figure out the amounts to add.
