Results 1 to 11 of 11
Thread: Pointing returns
    Dec 2010
    San Diego, CA
    1,137
    Pointing returns
    Here's my pool layout:
    Code:
    EAST
     _ _ _ _ _ _R_ w
    |.........3.5'...|
    |..........6'....|
    B................|
    B................|
    B..........3.5'..|
    B _ _r_ _r_ _s_ |
    WEST
    B = seim out ench (no stairs), r and R = returns, s = skimmer, w = waterfall, the bump out is a swim out bench. The waterfall is not usually on.
    The wind runs West->East 75% of the time and East->West the rest of the time.
    Today I have the return closest to the skimmer pointing at the deep end (the middle) slightly to the left of itself. The return next to it is angled towards the wall just past the swim out bench, just low enough to see surface flow without breaking the water too much. The far return (R) I have pointing straight ahead, flat.
    I want to put a return skimmer at R. But which way should I point the out flow? I don't think I get very good flow to the NE corner of the pool. So my initial thought is to point the return skimmer's output in that direction. Is this right? What about the other returns?
    I'd love to get suggestions for how to configure these with and without a return skimmer too.
    Thanks in advance
    Edited a whole bunch of times to get the pool layout right in the post; looked fine in the editor window; not anymore.
    I added a [code] tag, which seems to help. JasonLion
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pointing returns
    How about pointing them so they circulate the water in a clockwise direction.
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by bobodaclown
    Nov 2010
    Calera, Al
    271
    Ours circulate counter clockwise.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Dec 2010
    San Diego, CA
    1,137
    That's what I was going for with my current setup excel that te first return is pointing straight to the middle o the pool. I'll turn that one to the left a bit.
    What about if I put in a pool skim? Same thing?
    Apr 2011
    Murrieta, CA
    2,360
    From your sketch I interpreted that the pool is rectangular, If you added clock postions to it, 12 would have a return, 1 or 2 would have a water fall, 4 or 5 would be a skimmer, 6 would be a return, between 7 and 8 would be a return. Going on that assumption.
    From what I understand you want to in general you want water mixing and a surface current to carry things towards the skimmer. I understand your water feature doesn't always run, but you don't want to work against it when it is running. (it's opposite the skimmer) so that is why I recommended clockwise rotation. Hope that makes sense. When standing behind the returns you'd want them pointing towards the left.
    Dec 2010
    San Diego, CA
    1,137
    Thanks!
    May 2011
    Orange County, CA
    696
    Given what we know about the Coriolus effect (http://en.wikipedia.org/wiki/Coriolis_effect), for best efficiency the returns should be pointed to make the flow clockwise in the northern hemisphere, and counterclockwise in the southern hemisphere.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    The Coriolus effect makes no difference here. The effect is so small that you will never notice it and never be able to even measure an efficiency difference.
    May 2011
    Orange County, CA
    696
    Jason, a little tongue in cheek that I guess my emoticon didn't convey
    Dec 2010
    San Diego, CA
    1,137
    I should clarify that the reason I asked was that the upper left corner seems to get little movement because there's no return near that corner. The question I meant to ask was do I keep the flow counter clockwise (which is the consensus) or should I point the poolskim output towards that corner instead. Also I was trying to see if with the first return closest to the skimmer should I keep it pointing straight or add to the clockwise flow which has been answered too. Thanks all!
