Results 1 to 16 of 16
Thread: Mushrooms growing on Tile/Plaster line?
    May 2011
    S.E. Mass.
    15
    hi,
    Today I noticed something very unusual to me.
    In my plaster pool I found what looks like Mushrooms growing on Tile/Plaster line?
    These things are soft, yellow, spongy, mushroom looking growths all along the tile line where the tile meets the plaster....?
    We brushed it off and when I scooped some up it has a spongy texture ...looks like mushed corn on the cob kernels...I don't remember planting corn seed in the pool this year..I pretty much plant all my seeds in the garden.
    I know my calcium level is low (200) and I am in the process of raising it slowly to stay around 300-350.
    Could this be a calcium problem?...or
    Is this some wierd form of algae?
    my last readings were.....2 days ago
    Chl.........2.0
    PH.........7.5
    TA.........110
    CYA ......30
    CH.........200
    water temp 75
    I added 6 lbs. calcium chloride .
    Thanks guys, Paul
    30 year old Gunite, 2008 got a new quartz finish.
    Freeform, approx 20,000 gal.
    Haywood 36 sf D.E Filter & 1 hp Hayward Pump
    BBB now was Triclor.
    22,549
    Re: Mushrooms growing on Tile/Plaster line?
    Post a pic of it if you can.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    It could very well be clumped up pollen.
    One thing's for sure - someone's not brushing often enough!
    May 2011
    S.E. Mass.
    15
    Poor picture but this is what it looks like.
    Any Ideas?
    I brush about once a week, today was that day..
    Paul
    22,549
    Post a full set of test results, but I'm going to say you need to shock. At an FC of 2 your FC is too low for your CYA. You should never let it get that low.
    May 2011
    S.E. Mass.
    15
    ok I'll do it in the morning and post the results..
    I forgot to mention the pool is beautifully clean and clear.
    Thanks guys
    May 2011
    S.E. Mass.
    15
    Hi,
    Last night I added 1 Gal. 6 % to bring up the CHL to around 3ppm.
    This morning I got a reading of 0 ppm...? ( Something ate it up)
    Test results are;
    Chl.................0
    Ta..................95
    Ph..................7.5
    Cya................30
    CH.................230
    water temp.....74
    I added 6 lbs calcium chloride
    1 Gal. 6 % Bleach to bring it up to at least 3 ppm.
    also I added 3 left over Triclor sticks to raise the Cya & boost the Chl ppm.
    The Triclor is almost gone and will discontinue after Cya is around 35 ppm or its all gone.
    Am I doing ok?
    Should I shock tonight and do an overnight chl. ppm test in the am?
    Thankyou, Paul
    22,549
    You should shock and hold it there as often as once an hour. Don't worry about the OCLT for a few nights. You can do it if you want in the course of shocking but don't make a special effort.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Hi Paul, you need to bring the FC to shock level and keep it there until you pass the overnight test. Using The Pool Calculator and inputting your last posted test results, your shock level is 13. You will need a little over 4 gallons of 6% bleach to raise the pool to shock level and you will need frequent additional doses of chlorine to maintain shock level until you pass the overnight test.
    Your daily FC range is 2-6, since you were frequently dropping below your recommended level it is not surprising things were starting to grow! Keep in mind while you are using the trichlor and your CYA rises, your recommened FC level will rise as well.
    Love TFP? Become a
    TFP Supporter!
    May 2011
    S.E. Mass.
    15
    Thanks guys,
    I'll start tonight and I'll be back with the results as soon as I can.
    Thanks again,
    God Bless, Paul
    May 2011
    S.E. Mass.
    15
    Hi,
    I have a question about overnight chlorine loss?
    Last night I brought my shock level up to 14ppm.........
    this morning at 9 am it was 11.5 - 12 PPM
    But
    it rained a whole inch of rain last night.
    Will that much rain affect the overnight chlorine loss?.......2.0 - 2.5 ppm loss.
    Also,
    when I did the combined chlorine test this morning it showed 0 ppm CC ???
    Thanks guys,
    Paul
    Jul 2009
    Houston, Texas
    9,380
    CC will fluctuate throughout the day, so it is possible to have 0 CC and still need to shock. The rain should not affect chlorine loss that much. I would continue the shock process today and run another overnight test tonight.
    Love TFP? Become a
    TFP Supporter!
    May 2011
    S.E. Mass.
    15
    Hi,
    Things have been busy with new Bees and Chickens & family and of course the Pool.
    I have been keeping up with my shock levels around 14 ppm and the pool looks great now.
    No more mushroom's or any other critters growing.
    Todays readings
    Chl.................3.5
    CC..................0.0
    TC..................3.5
    TA..................100
    PH..................7.4
    CH..................290
    CYA................30
    Temp..............76
    Getting Better?
    Thank's for keeping me in line.
    Paul
    Richard320's Avatar
    Jan 2010
    19,000
    The numbers look pretty good, but the real question now is, is it clear and sparkling?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    FWIW... It rains almost every day here. grumble grumble grrrr grrrr.... On cloudy rainy days (like today and most of the past week), I can pretty much skip bothering with chlorine because it won't be till the next sundown till I'm even close to minimum.
    We rarely get a whole inch in one day but it's fairly consistent pizzing on us when the rain is here and it comes and goes all day/night. Rain does not seem to eat chlorine much if at all. What kind of organics are in rain anyway? It seems to be mostly pure water with city dirt in it which is likely not organic. If I recall correctly what a sun actually is (having only seen it a few times this year I'm a little fuzzy...) it's only when the sun shines through the clouds that I loose more than 1ppm of chlorine in a day.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    May 2011
    S.E. Mass.
    15
    Richard 320 and frogabog,
    thankyou both.....Rain, rain go away. It does not bother chlorine level, thanks.
    Richard, yes, pool is a pretty picture, all sparkling and clear.
    I will do my best to keep my chl level where it should be.
    I hope not to bother you guys too often.
    paul
