Results 1 to 12 of 12
Thread: Is it possible to gage the....
    Robins Airman's Avatar
    Jun 2010
    Bonaire, GA
    139
    Gals per hour capability of a pump by looking at the label?
    Mine has one listing different types of flow rates.
    I am trying to calculate the exact amount of time i need to run my pump each day in order to filter 14100 gals of water.
    Any help is greatly appreciated...Bo
    ***Edited to insert correct pics of pump label ***
    Thanks all for your amazingly helpful advice! Bo
    18x33 Morada pool, 14,100 Gal - 2HP, 2SPD W/Skimmer and Caplet Basket, 125 GPM Waterway ProClean Cartridge Filter System – 8 Gal LQ - TF-100.
    Thanks in advance for all your help!
    God Bless America!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Is it possible to gage the....
    What horsepower is it? I don't see any useful info in those pics.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Pumps are rated with a curve. You select the head of the system and then look at the appropriate curve for your pump and read GPM.
    Head can be calculated, but it requires measuring the vacuum on the inlet side of the pump.
    It's easier to just start with 8 hours a day and adjust as needed to keep the water looking good while minimizing run time.
    22,551
    There's a label right above the A.O. Smith label. What does it say?
    Apr 2010
    Western North Carolina
    44
    Try this...
    Get a five gallon bucket and have someone hold your vac. hose over your return. Be sure that you are getting 100% of the flow from the return. Then, with a stop watch, time how long it takes to fill the bucket.
    Example, If it takes 10 seconds to fill the bucket, your pump is pumping 30 gallons per minute. (10 seconds will divide into one minute 6 times. Thus, 6 X 5 gals. = 30 GPM) Multiply that by 60 and that will give the the GPH. In this case it would be 1800.
    Get it?
    24' X 52" AGP - On a concrete slab with 1" Dow blue foam board bottom.
    2Hp 2 speed Waterways pump/Cart. Filter.
    Hard Plumbed 20' away
    Deck 1/3 around pool
    Pool Rover Jr.
    DIY project
    Best Pool Store Quote, "THAT BLEACH WILL DESTROY YOUR LINER."
    Jun 2010
    Bonaire, GA
    139
    Quote Originally Posted by woodyp
    Woody...that is a Waterway 2 speed, 2 HP pump...i am not sure but the pic above lists two RPM's...one for each speed...i think.
    Bama...here is a pic of the label you mentioned.
    Thanks...Bo
    God Bless America!
    Jun 2010
    Bonaire, GA
    139
    Quote Originally Posted by tmyers
    Try this...
    Get it?
    Actually that makes total sense...thanks.
    God Bless America!
    Jun 2010
    Bonaire, GA
    139
    I just used MAS985's spreadsheet/table...used the PSI2GPM tab...according to it, using the lower of the two RPM's listed on the label above (1750/low speed RPM) and the average PSI my filter PSI gauge reads during operation (5 PSI, i clean it as soon as it hits around 6)...the result of that is 45.18 GPM...i rounded it down to 40 GPM to be safe and that comes out to one turn over every 6 hrs for a 14,100 gal pool.
    MAS985's GPM calculator is located here: http://www.troublefreepool.com/post6544.html#p6544
    I think I'll start there and adjust as needed.
    Thanks...Bo
    God Bless America!
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Actually that motor is a BN37 -- based on the current draw and it is a 2 spd... According the AO Smith Catalog is actually a 1 horsepower motor-- I have the same one on my Hayward and get about 36 to 40 GPM also
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    Jun 2010
    Bonaire, GA
    139
    Quote Originally Posted by dremin2flyhi
    Dang...so that sticker with the " HP 2.0 SPL" does not mean 2 HP?
    I bet my rookie butt payed for 2 HP when i got the pool...
    Thanks...Bo
    God Bless America!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    You may have paid for a 2 HP, but it would have cost you more in electrical usage. Think of it as an investment that saves you money down the road. (Trying to make lemonade out of lemons). LOL
    Jun 2010
    Bonaire, GA
    139
    Quote Originally Posted by bobodaclown
    Thanks Brotha!
    God Bless America!
