Thread: Air leak in skimmer line
    Hi,
    For the past few years I've had to turn off one of my skimmers because that line always takes in air somewhere. I always figured that the leak is somewhere underground and inaccessible but maybe I'm wrong. It's an old in-ground pool and filter but probably not the original filter; it looks like the hoses were rerouted to line up with the inputs/outputs. Is there any way to pinpoint where the air is coming from without busting up the pad around the pool? And if it is underground, is there any way to seal the leak- something like a pool version of antifreeze with StopLeak?
    Doug
    Doug
    Old 20 x 40 vinyl lined, in-ground. Hayward Perflex DE filter.
    22,550
    Re: Air leak in skimmer line
    Start by running water over all the piping you can see while the pump is running and see if the bubbles stop. You can even soak the ground where the pipe goes into the ground.
    Bama,
    There's not a lot of exposed piping but that sounds like an easy enough starting point. I haven't had time to open the pool yet this year. Hoping to get that done this week. Then I'll give it a try. Thanks.
    Doug
    Doug
