Results 1 to 9 of 9
Thread: Hi pressure,Low pressure
    Hi Everyone
    I recently changed the sand in my filter because I was getting no pressure on my return jets in the pool and the pressure on the filter itself was 30 psi. When I change the sand, the psi on the filter was about 12 psi with 8 psi on the return. Now it is back up to 30 psi on the filter with no pressure once again on the return. Has anyone had this problem??
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Hi pressure,Low pressure
    Welcome to TFP!
    Have you backwashed the filter?
    I've backwashed the filter, rinsed, even vacummed to waste still no change
    What does your water look like?
    its green now
    This situation has been on going for a month
    22,553
    Sounds like there is a lot of algae you're trying to filter out. Are you shocking the pool?
    SW Indiana
    9,199
    Quote Originally Posted by NolaBigDawg
    Hi Everyone
    What do you mean by "12 psi with 8 psi on the return"? Do you have more than one gauge? Do you backwash for at least 3-4 minutes? Have you tried operating the system with the filter set to recirculate to see if it is a filter issue or plumbing issue?
    I used five bags of shock, with no results
