Thread: Dirt cheap solar heating
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    I keep a hose more-or-less permanently attached to the spigot on my filter return line, as I drain and refill periodically to lower CH. But that's a different topic.
    The weather here has been bizarre; more like England than Southern California. So the pool just won't warm up, and I'm too cheap to run the heater. So I'm out puttering, and get the brainstorm last week and laid said hose on the patio, where it can get hot. The water's still coming and going to the same place, but this way it's getting warmed a little.
    Today, the sun finally came out of hiding, so I cracked the valve a little and have it warming again. I also have a black, 100' hose attached to the hose bib on the house. I need to add another inch or so to the pool, so I dragged that whole hose out on the patio and have the water just trickling into the pool.
    Cost? Running the pump outside the normally programmed time. That's it.
    Sep 2009
    Greentown, IN
    914
    Re: Dirt cheap solar heating
    Sounds like a great idea since you needed to add water anyway. You're probably not used to needing to warm your pool in S.California... so I can't say I feel sorry for you.
    Here in Indiana we had about one great week and lots of rain off and on since. As soon as the water starts to heat up (even w/our solar heat) it rains again and adds another inch or more of cold water to the pool. One of these days we'll be able to get back in it again!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    That's cheating Richard!
